Page 1 of 3 123 LastLast
Results 1 to 10 of 22
    Jul 2003
    mga peeps,
    sinong meron idea kung magkanu and saaan makakabili ng high volume and low pressure spray gun mas ok sna kung gavity feed. balak ko kasi mag-aral kung panu mag-paint ng sasakyan. thanks!!!!!
    The real good ones na HVLP are around P2K-5K. Ung gravity fed meron as low as 900 lang. Look for kimpoy meron siya nito sa store niya.
    Jul 2003
    salamay wildthing and san pwede macontact si sir kimpoy
    Jul 2003
    meron din ksi akong nakita na mura lang na spray kaso ndi ko alam kung ok yung units brand nya is "spray it" any comments on this brand of spray thanks.
    kimpoy post often sa Trucks, SUV forum.
    One thing you should look for is how the lid of the sprayer ay isinasara sa body (paint reservoir). AVOID the screw on type kasi if pressure build up (even HVLP can have a pressure build up)...nagbuburst open ang lid....sira na agad. Try those that have some sort of "hook-up" lock....
    hard to explain without the pics (but I don't have time to search my painting guides....sorry too busy).....but look around first muna and dont rush yourself in buying....makakakita ka rin ng iba't ibang type.
    Think of this scenario....you might be painting different colors agad so it would be nice if the paint reservoir could easily be replaced... it should also be easy to clean up (eto kasi ang pinakamatrabaho na part) for your convinience....it should also have lots of implements (nozzle change, adjustment of pressure etc.)
    Jul 2003
    wildthing,
    oks try to consult ung mga experts na pintor kung ano maganda gamitin na spray for painting thanks. i'll try to look for kimpOy.
    ako rin DIY painter pero ndi ko pa masyado kabisado. hook up din spray gun ko.
    paano ko ba madedetermine kung high vol low pressure ang spray gun?
    share mo naman knowledge mo saken. hirap mag liha at masilya sumasaket braso ko.
    The pro level HVLP's are at about 16k or so without the compressor.
    Ang importante sa HVLP is the source of air.
    If you use a compressor, make sure to get a very good filter drier.
    Use 2 or 3 in series if neccessary.
    OK gumamit ng HVLP, minimal overspray & very good yield sa paint used.
    Like any tool, kailangan lang experience ng operator para maganda finish.
    SATA(gravity fed) di ko lang alam kung magkano...AFAIK you should atleast have a 5 hp compressor....
    ayaw sabihin sa akin ng friend ko kung magkano kuha niya sa SATA...may consultation fee na raw he he...
    SATA nasa 7T last 2 years ago
    meron ako dito meduim duty 1100 only
    Spray it na Orig nasa 950
    check your pm dyafake!
High Volume and Low Pressure Spray Gun?
