Results 21 to 24 of 24
- 267
November 4th, 2005 12:38 PM #21Originally Posted by pajero gmbh
Pag di pa nakuha, me singaw ka pa rin somewhere...yung compressed gases from the combustion chamber tumatagas sa cooling system kaya may bula. Monitor mo yung water sa radiator kung nagkakalangis-langis and your oil naman kung nagkaka tubig.
- Mar 2004
- 74
November 5th, 2005 01:40 AM #22walang humahalong oil sa radiator ko. and water sa oil. sige i will bleed muna and replace rad cap. give you sirs feedback after.
November 17th, 2005 09:10 PM #23
Mga Sir... pano naman pag lumalabas water pag open yun radiator cap? I change na the thermostat ganon parin tapos newly overhaul radiator... pag wala thermostat rotating naman yung water... ano kaya problem nito? many thanks
September 6th, 2006 11:34 AM #24
up ko lang to mga sir... ganitong-ganito kasi nangyayari sakin ngayon.
diesel sportage ko din nang tubig sa radiator, pero hindi sa reservoir. if i let the engine run without the rad cap, may fine bubbles na lumalabas sa filler neck. diba dapat wala talagang hangin na lalabas don? i'm suspecting my head gasket to have a small leak. pano ba malalaman kung leaking na talaga yong gasket ko.
maraming salamat po...
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
