Results 11 to 13 of 13
- Jul 2005
- 61
October 14th, 2005 09:28 AM #11thanks sir...........
ganun nga ginawa ko. i have it checked sa casa and they used the mut computer they have. may sinasabi silang dudukutin daw. i don't know what they meant about that. pero kasama daw nga yung solenoid valve sa palit. ang labo nga eh. hindi niya ma-specify kung ano talaga gagawin dun sa dukot na sinasabi niya. umalis na ako at napipikon na ako baka dukutin ko pa mata niya eh.......hehehehehe.
- Sep 2005
- 40
October 14th, 2005 11:28 AM #12valve body lang ung dudukutin at ibaba hindi the whole tranny.pero kailangan mo rin bumili ng rebuilding kit para sa valve body.Naka kabit na dun ung 4 pcs solenoid valves pag binaba mo.sana walang diperencya ung end clutch mo(overdrive clutch) at brake band or else baba talaga the whole tranny ass'y.
suggest to check first your overdrive switch system baka dun lang ang problema bago ka mag proceed sa major works.
- Jul 2005
- 61
October 18th, 2005 10:09 AM #13i had the valve body replaced........minsan ok sha pero minsan nag slip pa rin.
when you are driving and you reached 4th gear, tapos nagmenor ka........when you step on the gas pedal now. nag-rev lang..........you have to wait na mag-downshift back to 3rd gear before umarangkada ulit.
surplus lang pinalit na valve body.
The Yokohama BluEarths notoriously break down as you use them. I guess something in their...
Finding the Best Tire for You
