Results 21 to 26 of 26
February 13th, 2006 10:33 PM #21
Originally Posted by BlueBimmer
February 14th, 2006 04:03 AM #22
Originally Posted by dx8976
There are other ways, of course.
February 14th, 2006 02:03 PM #23
How much is it to have the waterpump replaced tsaka yun rear subframe shock mounts? My 10 yr old E36 is ok but if it's a maintenance thing to have those replaced then i'll do that. Naka 70,000km na yun kotse ko. Thanks in advance.
February 14th, 2006 02:08 PM #24
recently changed my valve cover gasket and had a peek inside..tiptop condition pa pati ang timing chain. 52k kms.
March 4th, 2006 11:57 PM #25
Originally Posted by airshaq20
Check this Site Reset Oil Service Reset Light http://www.unofficialbmw.com/e36/ele...ce_lights.html
Tsikot Member Rank 5
- Nov 2003
- 3,848
March 5th, 2006 09:10 PM #26easy lang to reset the light as long as you have a tool, should't be too expensive pa.
have your compression checked... if Manual yang Montero mo... try mo patulak if ayaw mag start...
