Page 1 of 2 12 LastLast
Results 1 to 20 of 26
    Oct 2004
    Guys, remember last Friday kinuha ko na yung BMW ko from the CASA kasi they finally solved the alignment problem after more than a week!.....Tapos yesterday, gamit ko only after about 15 minutes on the road nagover heat na siya! I checked putol yung pipe that connects the radiator hose to the radiator....Its hard not to become suspicious.....baka sila din ang nakasira niyan? Di kaya? Pinatow ko yesterday at pinadala ko kaagad sa kanila ulit...
    My problem now is that I think I have to replace the radiator? or yung part ba that connects the pipe to the radiator can be replaced separately? Gastos nananaman ito! Pwede ko bang singilin ang CASA sa cse ko na ito? Thanks...
    i think they have to replace that for free. diba naka warranty pa naman yun?
    Hindi ganung ka simple yun.
    Ano ba ang edad/kundisyon ng hose/pipe? Bago ba o baka naman nasa end na ng life cycle niya?
    Dec 2003
    i think thats ur radiator neck, the plastic piece that the radiator hose connects to. ano ba mileage ng bimmer mo, kng mataas na thats normal. e36s are prone to overheat if the necessary parts are not replaced.
    in the case of my E36, pina-modify ko yung plastic radiator neck and replaced it with steel. This is one weak-point of the E36 even if its low mileage.
    Other weakpoints of the E36 is the water pump & impeller (better replace it with aftermarket like bosch), and the car's rear subframe and rear shock mounts. Aside from these weak areas, the car is built like a tank!
    If I were you, have it checked already. I recommend either AUTOVEC or ERL MOTORWERX. Both are "technically adept" in checking and diagnosing your teutonic car.
    Basics, Top Gear and the like are ok for "simple and not-too-complicated" works like changing oil etc...
    BTW, you may be interested in joining the BMW Car Club of the Phils. There are a lot of members with E36 who can share their experiences with various shops. If you're interested, call Manolet Ramos at 0918-9499289. Tell him Dindo Velasquez referred you.
    Dec 2003
    yup, thats y i replaced my waterpump, t-stat housing, t-stat in advance. maop pacheck mo na lahat n replaced in one go. if u can get the composite waterpump its much better, i stayed with italian plastic impeller cos its cheap n easy to replace.
    Sep 2002
    Quote Originally Posted by maop99
    which casa are we talking about here?
    That is so weird.....i drove my E36 (325is) for just over 2 years and never had a major problem with it.....The only thing that bothered me was the service lamp that lights up and i have to go to a fancy shop to have it reset..i used to change my own oil since i get my Mobil-1 oil real cheap.....but the only thing that i changed was brake pads and the 2 belts.....good thing is that they use timing gear/chain so i never worry about breaking it....aside from that, it was virtually maintenance free in my part (also true with my previous E46).
    Quote Originally Posted by airshaq20
    Check this Site Reset Oil Service Reset Light http://www.unofficialbmw.com/e36/ele...ce_lights.html
    Aug 2004
    Same thing happend with our e46..pagkalabas ng casa for a simple oil change, kung ano ano nasira. They told us na ganon na talaga pagpasok and we eventually had to pay for all the repairs.
    Dec 2003
    the m50 and m52 engines have timing chains afaik
    Sep 2002
    Quote Originally Posted by BlueBimmer
    how can one tell the difference between the 2 (m50 and m52)?
    Sep 2005
    Quote Originally Posted by dx8976
    The lazy way - M52 with the oil filler cap up front, way back for the M50 ... I think There are other ways, of course.
    Oct 2004
    Thanks guys, Woodfire, bluebimmer, you guys hit the nail in the head! yun nga ang nasira, I brought it to the CASA kasi sila lang ang may towing, yesterday eh, sunday pa naman and I was in a real hurry, so no choice ako....Di naman siguro nasira ang engine ko? Kasi I only noticed after maybe 20 minutes after I left the house, sana lang nasira siya just a few minutes before I noticed na naka-red na yung warning at di pa siya sira when I left the house, para di masyadong naapektohan yung engine....Woodfire, Bluebimmer, di kaya nasira yung engine ko? Thanks
    Dec 2003
    its unlikely na nadamage engine mo, observe mo nlang muna. common part na nasisira due to overheating is the thermostat, it will either be stuck closed or open which is both bad for the engine. palitan mo na rin para 1 tym service na with the waterpump.
    Oct 2004
    Okay thanks i'll do that....hay salamat...kala ko nadamage pa pati engine ko....
    Oct 2004
    Woodfire, Bluebimmer, di kaya i-modify/repair ng casa yung radiator ko and I don't want to get their radiator kasi super taga! Can you recommend a place na nagmomodify or gumagawa ng radiator ng BMW? Or okay na ang AutoVec and/or ERL? Thanks guys!
    Dec 2003
    its better kasi if u get a new radiator, baka hindi umobra ung repair sa old rad mo. never get parts from the $tealer, unless ok lng sayo hraphrapang hold-up hehe
    Oct 2004
    hehehe Thanks, oo nga baka nga i'll just get a new one, Do you know the number of Mike parts? may nagsabi sa akin na okay daw doon ang mga parts. Thanks again
    in my case, I didn't replace my old radiator. I just replaced the plastic "neck" with steel. the radiator of the BMW is really good and seldom conks out! only the "plastic neck" is the weak point.
Just came from the CASA, Sira nanaman ang BMW ko!
