Results 11 to 19 of 19
March 29th, 2006 02:10 AM #11
one of it is, someone told me na magiging mausok ng konti yung chikot mo!
March 29th, 2006 03:11 PM #12Originally Posted by pomelo
For other leaks, just look around your engine where oil is coming out. The rubber parts in those areas may need replacement as well.
Tsikot Member Rank 5
- Nov 2003
- 3,849
March 29th, 2006 11:08 PM #13no major effects naman. just a slightly more sluggish engine because there is more resistance because of too much oil. aside from that, dapat naman lumabas sa breather yung excess oil. simplest solution would be to drain the excess.
Toyota is my choice
- Aug 2005
- 2,063
March 30th, 2006 01:14 AM #14ito pa na experience ko na yung overfilling dahil nilagyan ko pa ng oil additives nag busted yun valve cover yung rubber. possible din na valve seals ang masira.. where nka locate yung o-rings? pag busted o-rings mausok ba?
March 30th, 2006 12:27 PM #15
ang pinakamahirap nito ay yun seal ng driveshaft ang masira. hirap palitan. stick to the manufacturer's specs nalang.
- Oct 2004
- 278
April 1st, 2006 08:13 PM #17crank skaft counter weights touching the oil level equates to at least 5HP power loss...
another thing is that if ever oil is way above the normal level, bubbles develop inside the engine... thus, oil starvation occurs because of the bubbling oil...
- May 2005
- 208
April 3rd, 2006 04:07 AM #18question: habang umaandar yung engine mo, tapos chineck mo dipstick mo,normal lang ba nasa low level yung oil? ty
- Nov 2003
- 3,849
high idle RPM at engine start
