Usually most of carb engine using conventional type of ignition system, the switching on and off of the primary voltage was done with a set of Breaker Points (contact point) but some of them in early 90's they are using an electronic type of ignition system, the points were replaced with a control module and the lobes on the cam were replaced with a trigger device.
