Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
    Apr 2006
    #21
    yup, sa pagkakaalam ko oscilloscope through waveforms ang madaling paraan para sa pag-analyze ng faulty electronic signals from primary to secondary ignition system. Ang hindi ko pa lang maintindihan bakit merong ganyan yung electronic type of ignition system or baka mali lang din ako baka may ibang gamit din yan for other components not in the ignition sytem. Kung sa conventional type of ignition system madali lang basta sunog na contact point mo isama mo nag palitan yung condenser. Yun kasi trabaho ng condenser for preventing voltage surges from ignition coil.
    May 2005
    #22
    Quote Originally Posted by Asus700 View Post
    to kaya yung condenser? pano mate test ito kung okay pa or needs replacing?
    according to chilton, this is the integrated ignition assembly (IIA) wire. no mention of the condenser being housed in it, hmmnnn
    Apr 2006
    #23
    OK thanks for the info, sorry about that. Its appeared of combining of distributor, ignition coil and driver circuit. Because of this it is basically eliminated the need of a high-voltage cable between the ignition coil and distributor.
humihinto
