Results 11 to 18 of 18
March 11th, 2005 01:35 AM #11Originally Posted by geris
March 11th, 2005 09:41 AM #12
The spark plug gaps vary from engine to engine... you can check your owners manual for that.
The Nissan Cefiro VQ engine only needs changing at 100,000km per the manual (it uses NGK platinum plugs).
- Jun 2005
- 3,774
September 30th, 2005 05:57 PM #13pano linisin yung ceramic na nandun sa sparkplug? the thread seems easy enough pero how about the ceramic? nagkakaroon din ng carbon builup dun eh... advice please
September 30th, 2005 06:04 PM #14
sa ceramic part parang sobrang konti lng e, punas lng mostly wala na, how come pati un may buildup sayo?
- Jun 2005
- 3,774
September 30th, 2005 10:54 PM #15yung sa ceramic diba nagingitim din yun kahit papano? or a shade of brownish-gray. thats what i was asking. how to remove the carbon deposit. when the spark plug is new, puti yun. pero habang ginagamit, nangingitim din yun. kapag sobra naman daw ang lean ng mixture, nagiging puti pa din yun kahit ginagamit. when you clean the plugs nagagawa bang puting-puti ang ceramic dun?
Tsikot Member Rank 5
- Nov 2003
- 3,849
October 3rd, 2005 10:51 PM #16don't think you should follow those suggested intervals. look at the difference in driving between the countries (philippines is all traffic while in europe you have long expanses of road)
that makes all of the difference.
- 299
October 3rd, 2005 11:03 PM #17re:Gap ng spark plug, nakita ko sa mga mekaniko yung thickness ng lagaring pangbakal ang gamit nila pang measure ng gap. lagay in-between, then little tap ok na.
July 30th, 2007 01:36 PM #18
kapag tama po ang air/fuel mixture natin, di na po kailangan pang linisin ang sparkplugs. kusa na po ito naglilinis sa sarili.
kaya dapat pong nasa optimal setting parati ang air/fuel mixture natin.
The backup charger finally arrived. Here are my findings and conclusion at the end:
