guys advise please.gamit ko spark plug bosch super 4,every 40T km daw bago magpalit,naka12T km nko pero dko pa nalilinis.paano maglinis nun.tnx
first you have to learn how to remove and install it.
most cars have a spark plug removal set included in its tools.
but i would also recommend using a torque wrench in the removal/installation process. because this is what the manual says. it even has the torque specifications.
to remove, turn counter-clockwise to install turn clockwise. do not overtighten.
i don't know what other peeps use but i've been using a small steel brush to clean my spark plugs. i just clean the electrode, check the gap, re-gap if needed and re-install it
hmmm...impression ko naman is you throw away the sparkplugs after every tuneup...hindi pala, o depende kung anong klaseng sparkplug?
i read in my car owner's manual that there's this sparkplug gap-measuring tool used to measure the distance between the cathode and anode(tama ba?)
First Remove Spark Plug Then Re-Gap if needed then Put a little gas.. not diesel.. then presto! its clean..
small steel brush na parang toothbrush ang itsura.. then one way strokes lang
parang ang hirap yata re-gap yun 4tips na sparkplug...
anyway, steel brush with fine bristles lang katapat ng maruming sparkplug. babad mo lang sa gas or kero to soften the carbon buildups before brushing.
sir ano yung antiseize?ano pano mag re-gap?pasensya na.Originally Posted by groucho
hi everyone
Sa europe, ang mga plugs ng mga mercedes ay pinapalitan lang ng dealer every 60T miles which is about mga 90T km or every five years. Ito kasi ang recommended ng mercedes pero nasasayo rin kung gusto mong palitan ng mas maaga. Pag nagseservice sila (mercedes garage) di nila tinatouch or nililinis man lang ito unless na may problema ang timing ng sasakyan. I think they use platinum or bosch plugs. Ang pinakamahalaga lang sa kanila ay to make sure na all fluids are up to the right level at gumagana ang lahat ng safety features ng saskyan and keeping it to the legal emission level. I used to change plugs every 6 months on my previous car pero di ko naman mafeel ang pagbabago kahit kapapalit lang nito. Kaya kung ako sa yo, kung okey naman ang hatak at idle ng car mo isave mo na lang ang trabaho para sa next service mo.
Ano ba ang tamang gap ng spark plug, meron bang pregapped nang available?
greyish color sya na paste. Ginagamit yon para hindi mag rust or ma stuck ang bolts/plugs in the future.Originally Posted by geris
The spark plug gaps vary from engine to engine... you can check your owners manual for that.
The Nissan Cefiro VQ engine only needs changing at 100,000km per the manual (it uses NGK platinum plugs).
pano linisin yung ceramic na nandun sa sparkplug? the thread seems easy enough pero how about the ceramic? nagkakaroon din ng carbon builup dun eh... advice please
sa ceramic part parang sobrang konti lng e, punas lng mostly wala na, how come pati un may buildup sayo?
yung sa ceramic diba nagingitim din yun kahit papano? or a shade of brownish-gray. thats what i was asking. how to remove the carbon deposit. when the spark plug is new, puti yun. pero habang ginagamit, nangingitim din yun. kapag sobra naman daw ang lean ng mixture, nagiging puti pa din yun kahit ginagamit. when you clean the plugs nagagawa bang puting-puti ang ceramic dun?
don't think you should follow those suggested intervals. look at the difference in driving between the countries (philippines is all traffic while in europe you have long expanses of road)
that makes all of the difference.
re:Gap ng spark plug, nakita ko sa mga mekaniko yung thickness ng lagaring pangbakal ang gamit nila pang measure ng gap. lagay in-between, then little tap ok na.
kapag tama po ang air/fuel mixture natin, di na po kailangan pang linisin ang sparkplugs. kusa na po ito naglilinis sa sarili.
kaya dapat pong nasa optimal setting parati ang air/fuel mixture natin.
