Results 1 to 10 of 30
SiRaNeko
- Jan 2003
- 973
January 26th, 2005 09:45 PM #1mas high octane na gas ba ay always better? is there such a thing as overdose of octane sa engines?
ang alam ko pag below octane requirement ang gamit mo na gas e mahina ang hatak and parang kinakapos ang engine.
your coments please
January 27th, 2005 09:32 AM #2
NO.
people assume this since race cars usually use high-octane gasoline.
only engines (usually new ones) that have a high-compression need high-octane gasoline (e.g. cr-v, rav4). though if you use a low-octane gasoline on these cars, the result will be poor fuel consumption & a drop in power (since the knock sensor will adjust your timing to compensate for it).
just stick to the recommended octane by the car manufacturer.
January 27th, 2005 09:34 AM #3
Just follow the recommended octane rating of the manufacturer for your vehicle. Dont go below this number to avoid engine knock. Going higher than this number is usually a waste of money.
January 27th, 2005 09:52 AM #4
Aside from what the guys mentioned, if you're running advance timing, it'll be also better to use higher octane fuel.
It varies from car to car as well... For some reason I noticed and got better fuel consumption on our Sentra when i used 95 octane Petron XCS over regular 93 (roughly 1-2km/L difference, and the gauge drop is less over the same route i take with the same driving habits). But with our Corolla 1300 before, there was no difference with low and high octane fuel consumption except that nawala yung tope pag tag-init.
January 27th, 2005 10:09 AM #5
basic thing to do is to test....
start with the lowest plain unleaded fuel. pag may naririnig kang engine knocks, try the next higher available fuel with a higher octane rating...
but if you can survive and your car runs on the lowest octane fuel available, dun ka na lang for practicality purposes. this is to assume that you are doing regular city drivings.
- Oct 2004
- 132
January 27th, 2005 10:47 AM #6Tama cla i guess. Isa rin ako sa naniwala na ok gumamit ng high octane gasoline on a bone stock motor. Anyway, i've read na most public available cars are engineered to run in low octane fuels. Assumption na un ng mga engineers since d nila alam kung cnu bibili ng kotse nila (bka kc 85 oct. ilagay ng mayari heheh). Pero unless ur tuning ur car and advanced ur timing from the factory set figure d mo kelangan ng high octane. An aggressive timing needs high octane fuel to prevent engine knock. They usually do this to gain hp i think and better fuel mileage.
Teka tanong ko na rin... pano ba malaman kung nagnoknock un engine by using ur ears only??? Anyone?
January 27th, 2005 10:58 AM #7
i always fill up with 95 octane fuel like XCS. middle ground nalang para safe. n dahil na rin some stupid gas stations cheat on their octane rating, baka ung 93 ng unleaded e 91 lng, mahirap na. saw it on tv.
SiRaNeko
- Jan 2003
- 973
January 27th, 2005 08:03 PM #8Originally Posted by vinj
parang mas maganda hatak sa akin ng petron xcs kaysa caltex gold. both are rated 95.
January 27th, 2005 08:08 PM #9
sir Bluebimmer akal ko po ang XCS eh for old cars???
ako po laging petron blaze or shell velocity
natatakot ako sa SHELL PREMIUM tsaka petron XCS eh.. balita ko kasi additives niya is for old cars daw... lead substitute ek ek.. please confirm this.
January 27th, 2005 11:22 PM #10
kadalasan ko gamit shell velocity.
pero nung nagkarga ako ng petron, xcs, parang antagal maubos compared to velocity...
pero stick pa din ako sa shell velocity. gusto ko lang.
car is 04 rav4. fellow rav4 owners, ano gamit niyong gas?
Planning to buy a second car. Help me choose. Honda accord has 71k mileage for ₱465,000 Nissan...
honda accord 2014 2.4L vs nissan altima 2015
