Results 31 to 40 of 45
- May 2019
- 54
January 31st, 2020 06:11 AM #31Update po again... Ngayon, Shock mounting and Shock ang papalitan another 20k.. Wala akong naririnig na ganon bago ko dalhin sa kanila ung sasakyan.. Haayss.. About sa manibela naman, natural lang daw na medyo humigpit.. Inadjust daw nila pero ganun parin..
Sure kaya na shock mounting ung parang squeaky sound na yun sa humps? Or kagaya ng sabi ng iba na pwedeng ung "Stabilizer"?
January 31st, 2020 01:30 PM #32
February 1st, 2020 10:24 PM #34
You're in a pickle but dont panic. The suspension parts do break after years of driving. These Mechanical wear and tear items. there are other shops that can repair these small parts. Dont think about this yet. You can delay this but not that long. Prioritize the steering "heaviness"
About the steering I suggest you visit other shop. They can comment on how heavy or extra heavy this is. Getting an opinion on it is very important. As suggested, speedyfix might be able to comment on it. Get opinions because if this steering is bad, then you can still chase honda for their bad parts&service.
- May 2019
- 54
February 3rd, 2020 04:55 AM #35Thank you po sa mga suggestion... Sige po, try ko po dalhin sa ibang shop, hindi sa nag titipid pero parang palaging may nasisira kada dala ko sa Honda Casa, after talaga gawin ung steering pump and gearbox, dun ko lang naririning ung squeaky sound sa humps, haaayz... May other list pa po ba kayo na trusted shop (Specialized or kabisado po ang Civic FD) near Imus/Bacoor/Dasmarinas, Cavite?
- Nov 2019
- 973
February 3rd, 2020 10:53 AM #37Shock issue that you have experienced after servicing from Casa might be due to the lifting of your vehicle via lifter.
May nabasa ako dito na ganun din na observe ng mga tsikoteer dito after ma lift yung sasakyan lalo na if medyo old na yung car.
Experienced it also at medyo nag stiff yung shocks pag dumaan sa kunting lubak-lubak.
Tumino yung shocks ko naman after nag road trip kami loaded with people yung sasakyan at napadaan kami sa rough road.
I am not sure if this fixes the issue.
Can't recommend this though since sedan yung sasakyan nyo.
Ipa 2nd opinion nyo na lang maam sa ibang shop.
Baka stabilizer link lang yung replacean nyan which just cost you around 400-500 for parts + 300 labor.
February 4th, 2020 02:58 PM #38
- Mar 2011
- 337
- May 2019
- 54
February 6th, 2020 01:53 AM #40Thank you po for the suggestion, will try Master Garrage after ko makabili ng mga needed parts.. Though sabi sa Casa pwede ko daw dalhin dun for labor and sakin ang parts, iniisip ko baka after nila gawin meron nanamang kakaibang mag occur na wala naman dati.. Kaya looking talaga ako for other Auto shop na kabisado ang FD na malapit lang sa imus/bacoor/dasma.. Will visit Master Garage, next week. Thank you!
high idle RPM at engine start
