naku! malaking tama yan!!! i use to be an estimator sa casa... get it estimated muna sa casa... para sure ka... umatras yung gulong mo sa wheel well eh...
sori to say.. but masama po tama mo.. quarterpanel.. pinakamasakit na matamaan na panel since ndi po sya bolt on. as much as posible.. try to retain the old quarter panel.. basta wala butas if honda tries to tell you that they want it replaced tell them try to fix it muna.. kahit sabihin pa nila.. plasma cutter gamit nila and all.. pag quarter panel is replaced.. ndi na parang original yan since cut and weld na.. kahit pa mahusay yung latero and pag pinutol yan masmadali kalawangin kesa sa rapainted panel. and dami papalitan sa mechanicals.. sa ilalim po
bali sa visible sa pic.. ang masusugest ko lang po palit and repair isbut ndi ako sure kung repairable pa yung iba coz of pic ko lang nakita)
replace:
door panel
lh rr door side moulding
lh lower side skirt
rr bumper cover
lh rr bumper cover moulding
1 pc mag wheel
1 pc tire
1pc mags center emblem
lh rr mudguard
mechanical parts(suspension)
tin job and paint job on:
lh quarterpanel
lh runningboard
but the important thing is malayo kayo sa pahamak since sa sides lang tumama
good luck po Cal. hope you get this fixed with no problem
