Results 21 to 30 of 41
October 7th, 2006 01:08 AM #21
mapapa aray nga ako ..crank shaft pulley pala..pati kaya bearing sira?
October 7th, 2006 01:32 AM #22
October 7th, 2006 05:21 AM #23
hintayin din natin mga GURUs dito baka mas may malalim sila i share
paging ..sir Speedyfix
October 7th, 2006 07:57 AM #25
pag nag-stuck-up ung crank-shaft bearing, idamay mo na ang timing belt at i pa check mo kun tumukod na ang valve sa cylinder..pag ganun, expect a good lump sum of money to be released-->magastos!
hope and pray na pulley lang at belt..... di din basta-basta nababasag ang pulley at belt.. had my maxima for 15 years, di pa ako nabasagan ng pulley....or sadyang di na maganda mga parts na kinakabit sa mga newer cars....once palang ako nagpalit ng crank/camshaft bearings and oilseals nunng pang-2nd time na ako naputulang timing-belt!
baka may tumamang hard object dyan or naipit kaya nabasag yan... aba, sa susunod, obserbahan mo gumagawa nyan...major components yan..buti kung body at ilaw/accessories lang...
pagkagawa, dont forget i-patiming mo ulit,ha!
October 7th, 2006 11:03 AM #26
nako madugo nga to..sana pulley lang.. sana nung nakita kong nagwiwigle plang yung pulley pinagawa ko na..
October 7th, 2006 11:50 AM #27nako madugo nga to..sana pulley lang.. sana nung nakita kong nagwiwigle plang yung pulley pinagawa ko na..
sana lang bro di tinamaan ang internals...
pray for the least
- Jan 2006
- 28
Toyota is my choice
- Aug 2005
- 2,063
October 8th, 2006 01:45 AM #29
hi bro.. pagawa mo asap.. kung bearing yan you can find cheaper bearing like NSK, koyo etc.. just let the auto shop see the bearing para ma measure nila ang size .. nsk and koyo are good brands.. bibili ka nlang sa bearing shop at dapat orig..
hint lng po yan para mka cheaper option ka sa bearing..
regarding sa pulley mukhang orig tayo dyan or kung may ibang surplus pwde na din.. mahal kc yan as far as i know.
sana wlang nabasag na iba .. sana din pulley and bearing lang.. para safe pa check mo lahat na possible damage
October 8th, 2006 03:29 PM #30
mukha malaking gastusan ito... sana wag madamay yung iba sa loob ng engine block...
WBR,
Xiaomi E-Car
