Results 1 to 10 of 12
August 26th, 2007 06:06 PM #1
Hello mga sirs, help naman po on how to install cold air intake on my
'94 honda esi.. balak ko kasi DIY ko na lang yung pag kabit para makatipid sa
labor.. TIA
August 28th, 2007 10:13 AM #2
What's your budget?
Do you need advice on how to install one, or how to make one? Because when you buy one, usually installation is free.
August 28th, 2007 12:03 PM #3
August 28th, 2007 01:16 PM #4
Can't help without pics. ;)
Wala bang instructions na kasama?
August 28th, 2007 04:44 PM #5
August 28th, 2007 04:50 PM #6
Well, if it's a CAI, just take out your stock air intake tube & filter... then replace it with the CAI tube plus filter then attach your MAF sensor too though.
Check where the CAI would "fit" in the lower part of your engine bay first though. Be prepared to put in an additional bracket / bolt to hold it firmly in place.
- Aug 2006
- 152
August 28th, 2007 11:17 PM #7Sir try this site for ideas!
http://www.ferraridoors.com/coldairintake.htm
HTH!
Tsikot Member Rank 5
- Nov 2003
- 3,849
August 29th, 2007 09:45 AM #8you might have to drill a hole in the body if wala pa dun to fit the tube... then remove the bumper to install it propely.
- Jul 2007
- 5
September 1st, 2007 04:34 PM #10
If it's made for the carb type, no need. If it isn't, you might have to go buy one.
