Results 11 to 14 of 14
February 7th, 2004 04:00 PM #11
ot: speedyfix, where is your shop located? mukhang pareho kami ng problem ni jeff108.
- Feb 2004
- 129
February 8th, 2004 01:08 AM #12jeff108,
Pag low profile yung gulong, there is much less room for sidewall flex kaya dapat taas ang pressures ng gulong, resulting in a harsher ride.
Yung lowered suspension naman, unless hindi binago yung spring rate, kailangan ng mas matitigas na spring para hindi madali mauntog yung rubber bump stops sa suspension. Ngayon, kung pinutulan yung rubber bump stops para mag-compensate sa shortened travel siguro ma-retain yung original spring rate pero delikado kung sumayad yung gulong sa car body dahil sa increased upward travel nito. To ensure na hindi sumayad yung gulong, ipa try mo na i max upward travel yung suspension (habang naka jackstands) without the springs or shocks, and with the tire on, and with the shortend bump stops on. Tignan mo kung sumayad ba ang gulong pag pina-liko mo yung manibela.
The conclusion of the matter is, any modification in the direction of lower ride height and/or lower profile tires will definitely increase ride harshness. I've never heard of, much less seen, a lowered car with a soft and smooth ride.
- Oct 2003
- 74
February 8th, 2004 02:17 PM #132..5 inches pa ung gap ng tires ko and fender..... hnd 2matama ung gulong ko s fender.
Nagpalagay nako ng shock stopper n goma kaya sure n hnd n mag uuntugan ung shocks ko pero bakit ganun im using a kyb shocks wala png 4 months bkt hnd n 2mataas ung shock ko pag pinisa ko pababa.... dko alam kung fluid o gas type ang gamit ko and anu ang mas ok gamitin n shockx pag nakalowerd k KYB o TOKICO....? kc ang alam ko pag malambot n ung shockx baka nag uuntugan ung lowerng spring n gamt ko kaya may sound n TOK pag nalulubak ako s small pavemnt pero pag malalalim wala nmng 2nog......... pero pag pinisa ko ung shocks ko matigas sobra hnd sya lumulusot..... matigas pag pinipisa ko hnd nga lang 2mataas..... dalawang shocks ko s front ganun hnd 2mataas but matigas.... ang sbe ng mekanik ang fluid type daw hnd 2mataas, matigas pag pinisa mo pababa, sumsabay s laro ng spring... wala rin akong nakitang tagas n oil s shockx kung fluid type ang gamt ko.... and ang alam ko nmn s gas type pagpinisa mo cya 2mataas , pero pag cra n lumulusot sya pag pinisa mo pababa ung shockx
Thank u for helping me guys....... really apprec8 it a lot
palitan ko n kaya ung shockx ko ulit? hnd n kc 2mataas e pero matigas sobra pag pinisa mo pababa and hnd cya lumulusot wala din tagas n oil ung shocks..... tnx
salamt s mga nagreply...
Tsikot Member Rank 5
- Nov 2003
- 3,849
February 9th, 2004 10:47 PM #14musang, jeff108
why don't you guys pass by the shop if you're in the area? just have my mechanic go with you for a spin then when narinig na nya yung ingay mas madali nya makikita kung ano sira.
look for felix if i'm not there
thanks!
