we all know na yun bagong cr-v ay matagtag anu pwede kong palitan d2....some say yun springs lng.....some say yun tires lng. pls help
if you have the 2nd gen CRV, you can buy japanese springs set from Honda casa for P8K. The ride dramatically improves. My bro's 2nd gen CRV had its springs swapped and it rides like the 1st gen CRV.
how about gen1 crv? an old one. ours has been 4 years old already, so suspension arent they used to be... ano pwede gawin dito?
27th_Faktory,
yep change the springs. yung sayo kase nung 8seater pa mas stiffer yung spring rates to accomodate the heavier load. naka 17" wheels ka diba? probably kahit magpalit ka shocks medyo matagtag pa rin yun pero at least there will be some improvement.
Ang papalitan lang dun rear springs. Front springs of the former 4x2 is the same as the current AWD CRV.
I test drove the Gen2 CRV at the fort before ..yep the AWD Gen2 now rides like the Gen1. Yung 8seater CRV noon ang matagtag lang na part nun yung sa likod lalo na pag wala load matalbog sya sa lubak or sa humps. Yung AWD CRV ngayon swabe bagsak sa lubak lalo na dun sa dirt course sa test drive
dieselNUBI,
change the shocks. Sa akin ganyan medyo luma na shocks I plan to change them too. If you want the same ride feel get the oem shocks from the casa. Pero for me I'd rather get Bilstein shocks for almost the same price (mas mura pa yata Bilstein compared to the oem shocks bought from the casa.
Supierreman,
nope hindi pa me nag papalet ng mags.....kung lowering springs kaya yun ipalet ko???? yun springs b ng gen1 and gen2 same size lng b?
dieselNUBI,
anung pangalang ng springs?
ok b yun merdyo labas tires?
27th,
meron din lowering springs available sa fusion R for Gen2. Pero most probably mas stiffer din ang lowering springs ng konti.
magkaiba springs ng gen1 sa Gen2.
pag nakalabas yung tires palaging madudumihan yung sides ng CRV mo eventually lalabo paint nun. better get wheels and tires with the proper offset or install aftermarket flares.
for further info check out this thread and read the post by Mikkomiks:
http://hondaclubphil.proboards24.com...play&start=120
HTH
hindi na libre forum dyn sa hcp........mag papalit na lng ako cguro ng springs pati tires gus2 ko yun tires ko malaki yun medyo mukang lowered pero hindi nakalabas ang tires.
27th,
yung CRV thread sa HCP nasa public forum pa rin : ) Register lang sa forum to view the link.
papalit ka ba ng low profile tires pero stock 15" wheel? mas better kung palit ka na lang ng wider tires 215/70-15 para mas maganda handling hindi pa gaano affected speedometer reading mo.
tama tama 215/70 ok yun lalaspagin ko muna gulong ko, hahahahaha how about the spring oo nga matagtag nga yun lowering springs. anung japanese springs yun sinasabi ni ghost. nag tanung ako sa planta kung mern yun. hindi pa bumabalik yun tauhan namin. anu b brand?
Originally posted by Supierreman
dieselNUBI,
Bilstein shocks huh? nasa magkano po ito?
27th Faktory,
Yung namention ni Ghosthunter yun yung OEM Springs from Japan orother markets...basta wag lang yung ganito sa atin hehe...special kase pinas kaya ngkaroon nyang stiffer springs na yan para lang dun sa added load :p
yep ubusin mo muna yang bridgstone duelers hehe.
DieselNubi,
wag po kayo magugulat... nasa around 27thou yung Bilstein...ako gusto ko rin magpalit pero tignan ko kung pumayag yung sponsor hehe.
But if you compare it to OEM shocks bought at the casa for 7,500 a piece (which makes that 30k for everthing!) dun na lang ako sa Bilstein... mas mura na performance shocks pa. Mahal talag pyesa ng Honda mas practical pa bumili ng name brand aftermarket parts.
Sa Civic ko dati ganun..instead of buying oem shocks nag bilstein na lang ayus pa.
di ba nasa 5,000+ lang each bilstein shocks? ganun kasi ang bili ko sa shocks ng patrol ko. so mga less than 22,000 dapat for all 4.
Signature
price of bilstein depends on the application. somtimes an application like the patrol can have cheaper parts since iba din yung design ng shocks.
you could also check out rancho and old man emu shocks. good reviews din on these pieces eh!![]()
