Results 21 to 30 of 33
BANNED BANNED BANNED
- Apr 2013
- 89
April 21st, 2013 01:19 AM #22
nangyari na sa akin to dati eh helicopter din tunog, un pala cause lang un cover ng engine sa side ng gulong nahulog un turnilyo kaya humahampas sa gulong
- Apr 2008
- 99
April 23rd, 2013 09:35 AM #23what's the recommended tire pressure for 195 55 R15 honda city '04? nagulat kasi ako nung nagpacheck ako last night, nasa 40 psi lahat ng gulong. pinabawasan ko muna to 30 lahat. ok na ba 30 for my car? do i need to increase/decrease para maiwasan yung tire noise.
April 23rd, 2013 09:57 AM #24
April 23rd, 2013 10:13 AM #25
- Apr 2008
- 99
April 23rd, 2013 10:35 AM #27
Pwede naman as there are undercoating bottles sold off-the-shelf. I'd recommend having it done by a service station/shop though as they will have to clean the wheel wells first to ensure there's no dirt and moisture trapped when they apply the undercoat and it will be done on a lifter with your wheels and some panels removed. Good to have it done now as well while the weather is hot so the undercoating tar will cure faster.
- Apr 2008
- 99
May 12th, 2013 03:32 PM #29
I have a similar problem. I had my wheels balanced and aligned and it turns out that my wheel bearings are due for replacement. It's a long process that will take a day though so I've put it off to next week.
- Jul 2011
- 1,711
May 12th, 2013 05:04 PM #30sir nilagay ba sa lifter ung car mo then piaikot ung wheels at detected na me tunog? Nung una kasi ang advise din sa akin ng mechanic wheel bearing, nag palit ako ng mechanic at inulit ung pag test sa lifter, ang final result ung tyres ko ang maingay, palit ako ng 4 tyres nawala ung ingay
high idle RPM at engine start
