Page 1 of 2 12 LastLast
Results 1 to 20 of 22
    Nov 2006
    peeps, ano ba usually ang cause ng hardstarting? problem with my car is hindi nman sya hardstarting in the morning when the engine is cold. hardstarting sya pag nag-stall or namatayan ako ng engine. suspect ko kse weak battery eh. i have to try starting the car 2-3 times which would take about 10-15 secs cguro bago sya magstart ulit. everytime this happens, kumukurap yung LED indicators sa dash when turning the ignition.. nakakhiya sa kasunod ko kaya i wanna have this fixed right away.. hehe.. kung weak battery nga, will having it charged at a battery shop be enough, or replace na talaga? almost 2 yrs na rin kse yung batt eh. outlast MF... much thanks...
    if it's your battery you will have a hard time starting it in the morning. check your ignition system specifically the ignition coil. a clogged fuel filter could also manifest this symptoms.
    Apr 2005
    I would also think that it is the ignition coil and/or the contact point. You could check on the primary and secondary windings of the coil if it is still within specification or alternatively, a crude method, when you encounter the problem, feel the ignition coil if it is very hot. If so, put a damp rag on the body of the coil, when it cools down, try to start it. If it starts immediately, then you could conclude that you have a faulty ignition coil.
    Nov 2006
    Quote Originally Posted by Gasoline Boy View Post
    sir G-boy.. i grabbed a digital VOM and tested my ignition coil.. as stated in Honda's user manual, the primary winding resistance should be 0.6 - 0.8 ohms, then the secondary winding resistance should be between 13.2 - 19.8 Kohms...
    my ignition coil resistance:
    primary - 0.8 ohms
    secondary - 16.33 Kohms
    pwede ko na kaya i-conclude na ok yung ignition coil ko? as far as my igniter is concerned, kapapalit lang.. or battery nga kaya?
    sir afrasay, given that my recent ignition coil resistance test is accurate, does it mean its just the fuel filter that needs to be checked or replaced to solve this hardstarting issue?
    thanks to the both of you...
    Aug 2005
    check mo power ng battery kpag ma fell mo na hardstart xya.. meron ata tester sa shop.. mag charge kasi bat kpag hindi mo ginagamit ang auto so pag start mo ulit for example sa umaga syempre mag start sya ng mabilis.. pero later on sa pag arangkada mo na at namatayan ka mahirap na eh start.. battery first ka muna mag check Imo lng.. or another way mag hiram ka ng battery sa ibang auto.. but be carefull sa honda kasi narinig ko lng kpag ecu na kailangan maingit sa pag palit ng old bat to new bat.. dahil mag reset pa daw ng ecu.. just heard of it..
    Nov 2006
    Quote Originally Posted by finchy18 View Post
    AFAIK, resetting the ECU is as simple as disconnecting the negative terminal of the battery.. correct me if im wrong though.. does resetting the ECU have a major effect on a car? diba usually nga ginagawa yun if you want to check for error codes... i guess i'll try having my battery charged first before doing anything with the fuel filter.. thanks finchy18...
    Aug 2004
    OT: Saan po ba makikita ang ignition coil? Exalta STA po.
    baka built in na sa distributor ang ignition coil niya. sometime it's a slight bulge sa distributor. Yun na yun ignition coil.
    Aug 2005
    Quote Originally Posted by wickednasty View Post
    try asking sa honda club .. di ko alam ang site nila..
    Oct 2005
    http://www.hondaclub.com.ph ...pero iba na ata...kasi down e.
    Aug 2005
    Quote Originally Posted by umzzzzz View Post
    pre musta na auto mo?
    Dec 2004
    check your grounding wires. Yung car ko dati hard start din, changed the battery and fuel filter yun pala yung ground lang pala ang cluprit
    Nov 2006
    ganun pa rin pre.. i just try to be extra careful with the clutch play para di mamatayan... haven't had time to check the fuel filter pero yun na next step na gagawin ko eh.. ano nga kaya nagyari sa honda club site?
    Aug 2005
    battery na check mo na?
    Oct 2005
    OT: uuuyyyy pareng finchy! ok lang naman. oldskul na. ikaw kamusta naman?
    Going Back: ung oto ko mga sir, paano kaya un, sumisinok sinok sya kapag umaandar. pero hindi naman grabe...tolerable naman... could this also be an igniter problem?
    Sep 2006
    ako naman i just changed the battery pero na eencounter ko intermitently na ayaw mag start... pag start ko di ko maririnig ung engine sound.. (mine is an a/t pala)ang ginagawa ko is on ko lang ung ignition den after mag initiate ung autolock ng car saka ko ino-on or ung alternative ko is... when i turn i start it... tinatagalan ko ng 5 secs sa start den saka lang aandar? wat might be the culprit?
    tnx in advance
    Sep 2005
    Here's the HCP site...http://z3.invisionfree.com/HCP/index.php
    Dec 2003
    try to remove the throttle body and clean it inside and out, ganyan sa ex crv ko pangit ng idle at biglang patay minsan.
    Jul 2005
    When you restart the engine, meron ba redondo or wala talagang response at all?
    even simpler, you could just pull out the ECU fuse (for 3 minutes or so) located in the engine bay fuse box.
    btw, resetting the ECU is a must in some cases when tinkering w/ your car. for instance, when i cleaned my throttle body last weekend (w/ the help of my kumpare) you're required to reset the ECU. otherwise, the car won't start, among other things; at least that's what happened to me
hardstarting culprit
