Quote Originally Posted by finchy18 View Post
check mo power ng battery kpag ma fell mo na hardstart xya.. meron ata tester sa shop.. mag charge kasi bat kpag hindi mo ginagamit ang auto so pag start mo ulit for example sa umaga syempre mag start sya ng mabilis.. pero later on sa pag arangkada mo na at namatayan ka mahirap na eh start.. battery first ka muna mag check Imo lng.. or another way mag hiram ka ng battery sa ibang auto.. but be carefull sa honda kasi narinig ko lng kpag ecu na kailangan maingit sa pag palit ng old bat to new bat.. dahil mag reset pa daw ng ecu.. just heard of it..
AFAIK, resetting the ECU is as simple as disconnecting the negative terminal of the battery.. correct me if im wrong though.. does resetting the ECU have a major effect on a car? diba usually nga ginagawa yun if you want to check for error codes... i guess i'll try having my battery charged first before doing anything with the fuel filter.. thanks finchy18...
