Results 11 to 20 of 20
July 10th, 2007 12:38 AM #11
check your ignition coil... and oh! dont hijack my thread.. haahahaha.. help guys. :D
July 10th, 2007 01:05 AM #13
the pumupugak pugak problem, solved already. Replaced the ignition coil, okay na. Hard starting still there, pero ibang symptoms naman..
hindi continouos yung crank.. parang kwenk......kwenk......kwenk....kwenk..
yung ..... pause yun...
This happens when the car is warmed up... and you turn off the ignition and turn it on again...
July 10th, 2007 03:30 PM #14
July 11th, 2007 10:09 PM #15
i tried to swap batteries with my moms car. tested it today and it worked like a charm.
my battery is defective. it doesnt give the right voltage when the engine bay and battery is already hot, resulting to hard starting and cranking.
my battery is ok when its cold, pag mainit andun ang problema.
July 12th, 2007 10:29 PM #16
pag kwenk3... kung mlakas battery bka sobra advance or rtard ang dstributor at pressure check ung fuel pump para mlaman kung tamang psi prin ang dlvry nya
July 26th, 2007 12:25 AM #17
oh edi ayos na car mo cocoy? battery lang naman pala ang prob, anyways maitnaong ko lang, may nagsabi sa akin na para matignan kung malakas pa ung battery mo is kelangan ishort ung battery, i mean ang ginawa ko is nagkabit ako ng booster cable tapos shinort ko, yellow ang spark, anu ibig sabihin nun? ang sabi sakin pag silver ang spark malakas pa ang battery, is this true??
- Aug 2007
- 4
August 9th, 2007 04:10 PM #18if you've done all that was posed here and still hard satrting pa rin car mo. try to check for vacume leak. isa rin cause ng hard starting yun and sometime its hard to accelerate at parang pupugak pugak pag may leak ang vacum ng car mo. try to check mga vacume hose, or try to check din yung distributor advancer mo baka may leak na rin at dun nag escape yung vacum.
August 9th, 2007 09:03 PM #20
sa akin sir nilagyan ng relay ung starter ko. before kci pag nagpaBOOM-BOOM habang rolling ok pa cya till makarating sa sa pupuntahan but hindi na cya iistart after. makauwi man ako the next day mauubos ung batt ko sa redondo ayaw magtuloy.
Xiaomi E-Car
