Results 21 to 30 of 31
February 13th, 2006 11:34 PM #21
Alalayan mo na lang using the gas pedal. Namamatay pa din ba if you do that?
February 14th, 2006 09:17 AM #22
tiger, guess what? 1 click siya kaninang umaga & i don't know why.
sir otep, that's what i did para di mamatay. ok naman kapag nakaalalay sa rev.
natatawa lang ako kasi nag-1 click kaninang umaga. must be the weather?
thanks for your replies.
- Feb 2005
- 44
February 15th, 2006 02:48 AM #23buti kpa mav ayos na! ako ganun pa rin... at hindi na ito sa weather ha... pasko plang ganito na ito ngaun happy balentong ha ganun pa rin!! : (
Toyota is my choice
- Aug 2005
- 2,063
February 15th, 2006 01:34 PM #24basa spark plugs dahil mausok or busted valve seals kaya tagal mag start especially sa morning dahil may langis sa tip ng spark tapos pag mainit na 1 start nlang..
palitan fuel filter/oil filter..
tuned up..
baradong fuel lines..
ayaw mag karga sa alternator.. dahil..
weak battery/ sira alternator di mag karga..
palitan ignition coil or pa kis2x mo na..
pwde rin carb cleaning na or carb overhaul..
mga ideas lng po yan baka andyan ang mga sakit.. yan kasi mga symptoms sa hard start.
I notice sa carb engine talaga pag Cold pump gas bago mag pa andar..Last edited by finchy18; February 15th, 2006 at 01:36 PM.
January 25th, 2008 04:23 PM #25
my problem's back again.
i'm thinking carb overhaul/replacement. 194T mileage ko.
any suggestions?
- Feb 2007
- 60
January 26th, 2008 07:59 PM #26Halos pareho ata yan ng na-encounter kong problem w/my corolla gl. Yung sa akin nga lang, nakailaw yung battery indicator sa dashboard and medyo matagal bago mawala even if I just had my tune-up and change oil 2 weeks ago and then I also had carb overhaul last month. Pinacheck ko batt and alternator. Solution is palit ng alternator. Spent 2,500 for surplus/reconditioned inclusive of labor. So far so good...
Tsikot Member Rank 5
- Nov 2003
- 3,849
January 27th, 2008 09:47 AM #27if you've never had the carb overhauled it's a good idea to have it done na.
- Jul 2007
- 10
January 28th, 2008 05:16 PM #28hindi kaya mga ser busted na yung auto choke niyo? yung sakin kasi patay na auto choke kaya ganito lagi, tutulungan sa gas sa umaga. check niyo din yung mga hose sa carb baka may tanggal. hth
January 29th, 2008 11:10 AM #29
sir ganyan din yung corolla ko ngaun pero hinahayaan ko na lang/..
yng akin mga 3 start 0 4 bago umandar pero pag nagmamadali ako itinatakbo ko agad
pag namatayan i jujump start ko na lang
- Jan 2005
- 157
January 29th, 2008 11:27 AM #30ganyan din nangyayari sa kin(97 XL) especially in the mornings or cold weather na idle for 10 hours up pero kapag nasa parking naman ng Bldg one click lack di na namamatay.
To all:
Paano and gaano ba katagal yung process nang carb overhaul?Ok ba dun sa Jun Jun and Danny's sa Kamuning malapit kasi ako dun?
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
