Results 291 to 300 of 364
- Aug 2004
- 163
October 29th, 2004 12:42 AM #291the same FUel Max that settled the charges in the US?
from the US Federal Trade Commission....
http://www.consumeraffairs.com/news/fuelmax.html
the manufacturer settled the charges instead of proving their critics wrong.
WASHINGTON, Nov. 9, 2001 -- The marketers of the Super FuelMAX automotive fuel-line magnet, advertised as providing dramatic fuel-saving and emissions-reducing benefits, have agreed to settle Federal Trade Commission charges that their claims were unsubstantiated.
IT'S "FUEL SAVER" SEASON!
Originally posted by the_wildthing
And as I said early in this darn thread...
And some guy is selling Fuel Max in the classifieds section... Hehe.Last edited by ericp; October 29th, 2004 at 12:47 AM.
October 29th, 2004 02:21 AM #292
http://www.pinoyexchange.com/forums/...0&pagenumber=2
Ischaramoochie said
well then, i'll just have to ask about that in the office. yes, the term "turbo" in the KSTC was not meant to be taken in its strict definition.
actually totally out of definition...
definitions for turbo:
This device uses exhaust gas to boost engine power. A small, lightweight turbine inserted into the exhaust manifold spins as exhaust gas goes speeding past. On the other side of the turbine shaft, fresh air is then compressed into the intake manifold. The more air that goes into the engine, the more power it can make. Unlike other forms of boosting intake pressure, the turbo used a virtually "free" source of energy in the form of waste gas. The knock on early "turbos" was a "lag," caused by the delay while the turbo came up to operating speed every time you floored the accelerator. Materials and technology advances have virtually eliminated this deficiency. Used judiciously, a turbo can actually improve fuel economy.
Ischaramoochie said
that fact may be true. however, the test conducted was not about mileage per se, but a comparison of mileage with and without the device installed. this means that city driving with and without the device would still exhibit roughly the same marginal difference in terms of mileage.
based on the sales material its mentioned "brings toxic carbon monoxide levels down to zero". Another parts mentions, "other pollutants like carbon dioxide & hydrocarbon were likewise brought down to the minimum".
But based on the test data vs the EPA standards, its shown that the hydrocarbon and carbon monoxide levels are very much above EPA limits. It cannot even qualify as a clean-air vehicle.
You have shown your test data. Are you saying there is something wrong with your own test data? Why do you not accept your own results/data that its exceeds the allowable limits for pollutiing gasses?
Ischaramoochie said
as has been said earlier, the installation of the device will not have an effect on NOx emissions since it does not lean out the a/f mixture above that obtained when stepping fully on the accelerator. given this information, NOx levels should not exceed those derived from normal operation. so much for the NOx issue. btw, what a/f ratio do you consider as "lean?"
what are your basis and support on your statements above? Are you an engineer? Are you the one who developed the device? What is your definition of "normal operation".
You thought simply by posting the test report data you can end this discussion?
btw, in the test report its mentioned that the TESTING CATEGORY was "Non-regulation". So where is your rigid testing? A demo done on some local government head's car?
Ischaramoochie said
and yes, you can obtain the same results by adjusting the air flow valve. however, this would cause above average ratios given full accelerator use. why shell out 6500? because you didn't think of it first. haven't you ever wondered why technicians charge a fortune just for replacing a screw?
well, then don't have them replace the screw. Just ask them how its done and do it yourself. Some people aren't stupid.
Ischaramoochie said
i'm aware of that. that's also why i said that there are many oxides of nitrogen; some are toxic and some are not. see my previous posts. now, if people would be more specific as to which particular NOx we are talking about, then the discussion can go on a bit more smoothly.
Farts are mostly methane gas, not NOx gas. And since we are talking about engine exhaust, I think we can safely assume we are talking NOx emissions from the muffler, not from biological sources.
Kindly keep to the topic and avoid diverting the discussion. You are just making yourself look more stupid.Last edited by ghosthunter; October 29th, 2004 at 03:07 AM.
October 29th, 2004 02:54 AM #293
I got lost there, who's replying to who?
Hope the results for the exhaust emissions test report get posted everywhere, in newspapers, magazines, TV.
Shame to those who did a section in their show for their piece of crap.
October 29th, 2004 02:58 AM #294
I never considered putting any kind of gas saving device in my ride, not because I don't trust the testing or review, but I simply i don't get the ROI of it.
Imagine imbes na ipambili mo ng gas saving device, ibili mo na lang ng fuel mo.
Haay naku, the most effective way to save gas, is don't use the car,
October 29th, 2004 03:05 AM #295Originally posted by Tiny
October 29th, 2004 05:14 AM #296
Iscaramochie is in PinoyExchange right? Don't have access to the site.
Hope we get to debunk the EGO and the other device in the workshop forums, 1 down 2 to go.
- 370
October 29th, 2004 10:59 AM #297My reply at HCP to a member with regards to why/how the device works.
Wala O2 sensor ang older cars.
Usually they will be taking idle fuel delivery based on TPS, MAP/MAF, ECT & IAT & reference it to a preprogrammed map which is programmed to ensure sustainable combustion under the worst conditions(hardly ever tuned up engine in cold weather with a clogged air filter for example) that would normally mean the idle mix is richer than neccessary.
Which is also why it's very effective on vehicle with "primitive" fuel metering systems.
That being the case a bypass like that would save fuel at idling but as mentioned at the expense of increased NOx levels.
Someone mentioned that there was an adjustment knob.
That would be neccessary to make the unit universal.
Let it too much air thru the device & it's like having a vacuum leak in your intake system.
We all know a big enough vacuum leak is detrimental to your engine's operation.
Device's like that work only if you spend a lot of time idling, like when your stuck in traffic.....
Are we getting ideas yet? ;)
Try using that on a vehicle equipped with 02 sensors & on the open road & see what happens.
I know I won't be getting any miracle fuel saving device anytime soon.
I've been around too long. :P
- 370
October 29th, 2004 11:02 AM #298Regarding the EGO.
This will explain partially what it does.
http://www.supertrapp.com/disc_techn...technology.htm
But that's not to say that it doesn't have it's own disadvantages.....
October 29th, 2004 11:11 AM #299
lahat iconsolidate na dito, at pag may nagtanong sa kung saan saang forum link this thread nalang nang matauhan at d na magtanong hehe
Tsikot Member Rank 4
- Feb 2004
- 1,704
Try mo sa Hino Parts Specialist sa may Grace Park, Caloocan. Search mo nalang sa google maps or...
Hino 300 Series Light Truck (Dutro)
