Results 261 to 270 of 364
- Aug 2004
- 36
October 25th, 2004 07:08 PM #261Sorry po, double post...
- Aug 2004
- 36
October 25th, 2004 07:13 PM #262Originally posted by ghosthunter
The device basically cheats the mass air flow sensor by introducing air into the intake that is not measured. That's why the engine would be running lean with the device installed.
The other devices would detect the changes.
-Manifold absolute pressure sensor (lower vacuum pressure)
-Oxygen sensor (leaner mixture)
In more complex closed-loop engine management systems, the ECU will use the data from the oxygen sensor and adjust the air-fuel mix to reach stoich levels, basically nullifying any changes by the device.
sorry sa mga double posts... nagta-time out ang connection ko so i have to refresh the page... iyon yata ang nagco-cause ng double post.
anyway...
is it safe to say sir that the device INDEED saves gas in such a way that Air is added so ang burn ng makina mo is sobrang lean? That's why we have NOx (by product of burning too lean?) tama po ba Sir/Ma'am?
- Nov 2003
- 71
October 25th, 2004 07:26 PM #263Hindi nga, kasi katulad nitong F-150 na di-otso (4.6l V8) may MAF sa intake, kung mag-introduce ka ng unmeasured air (bypass) magiging lean, kaso pag dating sa exhaust manifold downpipe may sensor uli, tawag Oxygen Sensor na magsesense ng presence of oxygen sa exhaust gasses, kapag nasense na meron oxygen (meaning lean condition) hahabaan ng ECU yung fuel injection timing para itama yung maling a/f ratio. Kaya walang effect ito sa mga klase ng sasakyan na may mga ganitong intake and emission control sensors. If you know you have these sensors and how they work you wouldn't have that device intalled.
- Nov 2003
- 71
October 25th, 2004 07:42 PM #264Sa NOx naman, magi-introduce ng exhaust gasses yung Exhaust Gas Recirculation (EGR) valve, ecu controlled din ito para bumaba yung temperature ng combustion. F-150 is ULEV, ultra-low emission vehicle pero "gas-guzzler" dahil hindi pwede i-compromise yung emission standards. D bale malakas sa gas huwag lang mag-pollute ng hangin.
October 25th, 2004 08:12 PM #265Originally posted by odeereambillo
Sige, it DOES save gas, if that's what you've been waiting to hear. But whatever amount in fuel the device "saves" is automatically offset by the costs of repairing the damage which will eventually plague your engine in the long run, because of continuous running on an improper a/f mixture.
Then of course, there is the moral cost of knowing that you contributed to increasing the incidence of respiratory disease, and for what? Para lang makatipid ng barya sa gasolina? That's being a little selfish now, isn't it?
And no, a test on my vehicle is out of the question. Not when I still have two years and 11 months on my warranty.Last edited by Bogeyman; October 25th, 2004 at 08:23 PM.
October 25th, 2004 10:56 PM #266Originally posted by odeereambillo
Sir,
It will also cause a few other things too:
-hotter combustion temperatures
-very big increase in NOx emissions
-motor oil degrades faster
-engine valves gets hotter, possible damage over long run
-detonation, engine knock, ping might occur especially on hotter days
-possible piston head damage
-possible piston ring damage
-possible gasket damage
-NOx can combine with water vapor to produce nitric acid
-acid can prematurely degrade your expensive muffler and exhaust system.
-increase of NOx in the air and sunlight will cause increase in smog levels
-increase of NOx in the air will make anyone with respiratory problems worst
-increase of NOx in the air will cause acid rain
-acid rain can dissolve concrete and stone buildings, statues, even your car's paint job prematurely
-acid rain can and will kill forests and rivers (if we have any left)
- Aug 2004
- 36
October 25th, 2004 11:33 PM #267Originally posted by ghosthunter
If and when your device does work (lean air fuel mix), it does save some gas.
assuming it leans a/f mixture (which saves fuel consumption), you also mentioned earlier in this thread that the ECU still have its O2 and manifold absolute pressure sensors to correct A/F... sir di po kaya the device helps the entire Fuel System achieve STOICH levels at any given state (idle, high speed, braking, gear shifting, etc) of the engine?Last edited by odeereambillo; October 25th, 2004 at 11:45 PM.
- Aug 2004
- 36
October 25th, 2004 11:34 PM #268Originally posted by ghosthunter
so how did Mr Planas test his device for zero pollution claims?
[/B]
sa Taiwan po pina-test ang Khaos for pollution...
- Aug 2004
- 36
October 25th, 2004 11:42 PM #269Originally posted by Bogeyman
Naman, you make it sound like a good thing, hehehehe.
Nabanggit ko din po sa mga unang bahagi ng mga posts ko sa thread na ito na ako man ay namamangha sa ginagawa ng device na ito sa pagpapatipid sa konsumo ng gasolina.
October 26th, 2004 01:14 AM #270Originally posted by odeereambillo
Sir,
BTW, not all cars are equipted with a closed loop ecu.Last edited by ghosthunter; October 26th, 2004 at 01:25 AM.
Yaris Cross: ₱ 200,000 for S HEV Zenix: ₱ 150,000 for 2.0 Q HEV CVT
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
