In order to provide the correct amount of fuel for every operating condition, the engine control unit (ECU) has to monitor a huge number of input sensors. Here are just a few:
Mass airflow sensor - Tells the ECU the mass of air entering the engine
Oxygen sensor(s) - Monitors the amount of oxygen in the exhaust so the ECU can determine how rich or lean the fuel mixture is and make adjustments accordingly
Throttle position sensor - Monitors the throttle valve position (which determines how much air goes into the engine) so the ECU can respond quickly to changes, increasing or decreasing the fuel rate as necessary
Coolant temperature sensor - Allows the ECU to determine when the engine has reached its proper operating temperature
Voltage sensor - Monitors the system voltage in the car so the ECU can raise the idle speed if voltage is dropping (which would indicate a high electrical load)
Manifold absolute pressure sensor - Monitors the pressure of the air in the intake manifold
The amount of air being drawn into the engine is a good indication of how much power it is producing; and the more air that goes into the engine, the lower the manifold pressure, so this reading is used to gauge how much power is being produced.
Engine speed sensor - Monitors engine speed, which is one of the factors used to calculate the pulse width
Sir,
is there any chance that the Khaos (fuel saving device) can fool/cheat these sensors?
