Originally posted by ghosthunter If and when your device does work (lean air fuel mix), it does save some gas.
It will also cause a few other things too:
-hotter combustion temperatures
-very big increase in NOx emissions
-motor oil degrades faster
-engine valves gets hotter, possible damage over long run
-detonation, engine knock, ping might occur especially on hotter days
-possible piston head damage
-possible piston ring damage
-possible gasket damage
-NOx can combine with water vapor to produce nitric acid
-acid can prematurely degrade your expensive muffler and exhaust system.
-increase of NOx in the air and sunlight will cause increase in smog levels
-increase of NOx in the air will make anyone with respiratory problems worst
-increase of NOx in the air will cause acid rain
-acid rain can dissolve concrete and stone buildings, statues, even your car's paint job prematurely
-acid rain can and will kill forests and rivers (if we have any left)
Sir,
assuming it leans a/f mixture (which saves fuel consumption), you also mentioned earlier in this thread that the ECU still have its O2 and manifold absolute pressure sensors to correct A/F... sir di po kaya the device helps the entire Fuel System achieve STOICH levels at any given state (idle, high speed, braking, gear shifting, etc) of the engine?
