Results 1 to 13 of 13
    Dec 2004
    what could be the problem with my ride?
    ito napapansin ko..car is running perfectly fine when the gas tank have say more than 2 liters of gas.
    but once gas level indicator 'nears' the warning line (empty warning light not yet on), it suddenly decelerates (but it does not totally stop), even if youre pressing on the accelaration pedal. this would last for a few seconds only then it would run smoothly again.
    cycle continous until your next visit to the gas station.
    the fuel pump has been replaced (oem) lately.
    what could be possible causes related to these symtoms?
    ride is 92 nissan SS.
    TIA!
    dirty fuel tank might be the cause. The dirt might be clogging the fuel pickup inside the fuel tank.
    Solution would be to have the fuel tank flushed and cleaned.
    Dec 2004
    pero why does it only happen when the gas level is low?
    Quote Originally Posted by jing
    its because the dirt is "floating" near the bottom of the fuel tank. And since the fuel pick-up would be near the surface, the only time it will be floating in the dirty fuel is when the fuel level is low.
    Jun 2004
    maybe bec. the sediments and dirt are at the bottom of the fuel tank, also since the fuel is low, maybe the fuel pump works harder to get fuel...
    Dec 2004
    thanks for the replies!
    next question is, san ba ito pwede ipalinis? at magkano usually ang labor charge?
    is flushing/draining of fuel tank part of preventive maintenance checklist? kasi i have not done this before. ngayon plang kung sakasakali.
    fuel pump was replaced less than 6 months ago.
    the problem is not how much... its how long. It would take half a day or longer (to take down the fuel tank, clean it and re-install it) depending on where you are going to have it done.
    Usually mga 1K, almost all gas stations na malaki-laki does this... Si Migs (speedyfix) offers this as well.
    Dec 2004
    thanks!
    will do this over the weekend!
    Apr 2005
    suggestion lang, ipa-drain mo muna fuel tank to see if the gasoline inside is indeed dirty.
    Jun 2005
    pag ibababa ang gas, siguro maganda na yung fuel ipa-salo mo sa isang lalagyan para naman di sayang.... tapos pag malinis na yung tank, ibalik mo dun sa tank after having it run through some sort of filter.
    Quote Originally Posted by sirkosero
    the dirty gasoline you would find after you drain a gas-tank would look like coffee some creamer poured into it. I'd rather dump it (or use it for cleaning purposes) than return it to the fuel tank.
    It would be too troublesome to assemble some sort of filter just to save a few liters of dirty gasoline. And the possibility of the gasoline being comtaminated by water (either from the gas-tank or from the container) is another problem to consider.
    boss, sa palagay ko deffective yung sending unit mo since sabi mo the prob only occurs when its almost empty,solution , don't let your gauge go below 1/4 ... maintain it for a few days and if it won't happen again, that must have been the one
Gas Level Related Problem?
