Results 11 to 13 of 13
- Jun 2005
- 3,762
February 28th, 2006 12:37 PM #11pag ibababa ang gas, siguro maganda na yung fuel ipa-salo mo sa isang lalagyan para naman di sayang.... tapos pag malinis na yung tank, ibalik mo dun sa tank after having it run through some sort of filter.
February 28th, 2006 02:00 PM #12Originally Posted by sirkosero
the dirty gasoline you would find after you drain a gas-tank would look like coffee some creamer poured into it. I'd rather dump it (or use it for cleaning purposes) than return it to the fuel tank.
It would be too troublesome to assemble some sort of filter just to save a few liters of dirty gasoline. And the possibility of the gasoline being comtaminated by water (either from the gas-tank or from the container) is another problem to consider.
THE AUTO SPECIALIST
- Mar 2006
- 607
March 6th, 2006 01:08 PM #13boss, sa palagay ko deffective yung sending unit mo since sabi mo the prob only occurs when its almost empty,solution , don't let your gauge go below 1/4 ... maintain it for a few days and if it won't happen again, that must have been the one
Kwento ng katrabaho ko, meron daw sya officemate dati na Italiano na tinanong daw bakit...
Traffic!
