Quote Originally Posted by sirkosero
pag ibababa ang gas, siguro maganda na yung fuel ipa-salo mo sa isang lalagyan para naman di sayang.... tapos pag malinis na yung tank, ibalik mo dun sa tank after having it run through some sort of filter.
the dirty gasoline you would find after you drain a gas-tank would look like coffee some creamer poured into it. I'd rather dump it (or use it for cleaning purposes) than return it to the fuel tank.
It would be too troublesome to assemble some sort of filter just to save a few liters of dirty gasoline. And the possibility of the gasoline being comtaminated by water (either from the gas-tank or from the container) is another problem to consider.
