Page 1 of 2 12 LastLast
Results 1 to 20 of 23
    Feb 2009
    over the years, chrysler, dodge, plymouth and now jeep had little holes drilled on the lower part of the muffler to drain the water byproduct of combustion. fuels which are carbon compounds are burned inside to the engine combining 21 % of the air produce H20 (water), NOx, CO, CO2, O2 and unburnt fuel HC flowing through the exhaust system. all of them are in gaseous form except for water which collect at the bottom inside of the muffler. now, other manufacturers are following suit for the same reason of extending the service life of the muffler. if you don't have a weep hole on the resonator of the muffler, water sits and constantly react with steel. remember, rust never sleeps. if you drill holes, don't be surprised to notice water dripping. the size of the hole can be as small as 1/8 of an inch (could be smaller) without any change in the sound or silence of the tailpipe with the engine running.
    Jan 2009
    Good to know. I'm not aware if said holes exist in our vehicles. Would be interesting to find out.
    papayag ba ang emissions testing facility, kung may butas nang ganyan ang ating mga muffler?
    Jan 2009
    I don't think they care.
    In all the years I've had my vehicles emissions tested, there wasn't a single time they even attempted to inspect any portion of the exhaust system. They just put the probe in and that's that.
    well,
    i'm a law abider...
    Yup, hindi naman kasi nila alam yan dahil hindi nachecheck.
    Jan 2009
    well,
    i'm a law abider...
    How is it illegal? Especially if it came out like such from the factory?
    Feb 2009
    what do they know, they don't even have or not know how to use a five gas exhaust analyzer. if you ask them why there is water vapor out the exhaust they probably can't explain.
    the u.s. epa clean air act uses california specs now. before year 2000, there were california and federal and canada emissions specs.
    even then, chrysler cars had weep holes on the mufflers prior to obd1 and now obd2 compliance. so, in that quasi concern if it was legal or not is no doubt not a problem.
    Mustang muffler drain hole
    Jan 2009
    There are a number of YT videos where people have drilled holes on the lowest part of their muffler, giving the stagnant water a way out. Judging by how much water is coming out, I'd say it can be anywhere from a few hundred milliliters to a liter, maybe more... depending on the size of the muffler.
    Notice that if a car in front of you is on an incline, you could see water dripping out the tailpipe. This could mean that his muffler is already likely filled with water and tipping it slightly allowed some of it to spill out.
    in my opinion, if manufacturers designed their mufflers' insides right, and angled the descent of their mufflers into the tailpipe,
    there may be little need to drill drainage holes.
    With the heat and pressure of the exhaust gases, any condensation (likely minute anyway) will just dry off and be expelled later on.
    Jan 2009
    The muffler is a chamber and it's installed almost always, horizontally. The outlet pipe is more often than not, higher than the lowest part of the muffler. It has to be standing vertically to make sure water doesn't accumulate.
    Good point. Though water is a by-product of combustion so there's always a steady supply of it, however minute, every time the engine is running. It may be possible that high ambient temperature and high EGT is enough to vaporize whatever amount of water has collected. But that may be dependent on a lot of other factors.
    why?
    exhaust gas is very fluid, and is not easily prone to the effects of gravity.
    it does not have to be perfectly vertical.
    to effect gravity drainage, a mild slant is fine, in my view.
    Jan 2009
    why?
    When hot vaporized water (ie. steam) from the exhaust gas gets into contact with the relatively cooler surfaces of the exhaust system, it changes state (condenses) to water. It then collects on the lowest parts of the exhaust system due to gravity. One such area is the muffler.
    Those of us who have diesel-powered cars, and even those who prefer gas, we sometimes spray water into the exhaust pipes to clean out the soot and carbon build up, especially prior to the annual registration (I know one here even custom-rigged a pipe fitting just for this purpose). Once you start up the engine, water left inside gets pushed out with some force. So I would not really worry about this.
    Jan 2009
    It's predominantly a problem in cold weather or climate. Less of a problem in hot weather, but it's there regardless.
    Feb 2009
    in dry areas or low relative humidity, the steam from the exhaust is less obvious but the byproduct of oxidation( combustion) of hydrocarbon + oxygen will always result in the formation of H2O. you can't avoid this phenomenon. in the case of dirty diesels, the soot usually combines with this condensed water droplets. the fuels which contain traces of sulfur too, creates some acidic compounds as H2SO4 or sulfuric acid that accelerates corrosion on the exhaust system.
    a perfectly working catalytic converter(reduction catalyst and oxidation catalyst) converts the pollutants into inert elements. the reduction catalyst breaks down the NOx(when the combustion temperatures reaches or exceeds around 2500 degrees fahrenheit) into O2 and N2. then the freed up oxygen is fed to the oxidation catalyst to further oxidize the CO and HC(unburned or incompletely burned fuel)
    Feb 2009
    the maximum allowable exhaust backpressure on most cars is 1.25 psig right before the catalytic converter. behind the catcon is usually at atmospheric pressure or 1 BAR. the pressure is not sufficient to expel the accumulated water condensation
    Yeah its not...
exhaust systems
