Results 21 to 28 of 28
July 2nd, 2007 08:24 PM #21
I think its a clogged radiator.
A stuck open thermostat will not give a higher temp than normal. It gives a lower temp than normal.
The fan can also be a culprit but it is unlikely since you say that it is turning.
I think its cheaper to clean a radiator that replace a fan. Elimination process.
July 2nd, 2007 08:31 PM #22
Kung stuck open thermostat temp reading should be lower than normal and not the other way.
If your thermoswitch is new and the fan is turning i doubt if that is the problem.
Low oil level can also lead to overheating. How is your oil level?
All factors considered i would go for a cleaning of the radiator.
DIY to death!
- Jan 2003
- 451
July 3rd, 2007 04:48 PM #23The behavior may be different for different vehicles. My experience before was almost the same as his. Car had no thermostat, radiator was fine, thermoswitch for the radiator fan was fine.
From a cold start and just idling, the temp does rise, medyo matagal nga lang. At a little above 1/2, the thermoswitch activates the fan until it goes a little below 1/2. Cycle continues.
If the car's running, the temp would never go past 1/4. The faster water circulation and constant airflow through the radiator would keep the temp cool.
When I installed a thermostat, temp would rise quickly to 1/2 and stay there.
July 3rd, 2007 05:04 PM #24
this might be an OT:
can an erratic temp. guage sensor will cause your car not to start lalo na kung nababad sa hot sun? pero pag binuhusan mo na ng cold water yung sensor, ayun 1 click na....
mostly lalo na kung electronically controlled engine ang may ganitong malfunction kaya?
July 3rd, 2007 06:01 PM #25
July 3rd, 2007 08:25 PM #26
it could be all three.
why don't you have your radiator checked and cleaned (if necessary) first. afterwards observe if the temp still goes low at high speeds and goes high at traffic. if this is the case either your thermostat is stuck open or you don't have a thermostat installed. last are the fans itself.
Tsikot Member Rank 5
- Nov 2003
- 3,849
July 3rd, 2007 10:32 PM #27alam ko in some cases mitsus will have starting problems related to the temp sensor. haven't heard it in other cars tho...
Tsikot Member Rank 4
- Jun 2006
- 2,605
July 4th, 2007 07:58 AM #28Thanks to all of your replies.
I have a thermostat. Brought the car to Dallas for Lavramon (tama ba spelling) their mechanic was honest enough to say that he can't do it.
Used the car yesterday (very hot day) on multiple short trips. Temp guage was normal all day. Even at 1pm at Edsa, mix of stop and go and fast runs, temp was fine. It stayed a little above 1/4. I'll continue to observe for now. Hope it stays ok.
