Results 1 to 10 of 32
- Jun 2013
- 188
November 8th, 2019 02:34 AM #1Mga sir, ang engot ko
Did I damage the car/rims/tires? Not sure how long I've been driving it malambot. The steering became stiff today on my way to BGC. Left the car parked for about 10 hrs, going home I noticed that the front left tire looked malambot. I decided to drive it home because imo it didn't look that bad. I'll have it inflated at the gas station near my house. Drove EDSA for 60-80 kph and didn't feel anything different in the steering since I was just driving straight. I did not hear any kalampag too. When I got to Shell, the air in the front left tire was only 13 na dapat 30. The rest of the tires were at 29 so it looks like napako or something yung front left tire.
Does casa repair tires or is there any place in BGC that can repair tires?
November 8th, 2019 02:56 AM #2
Ok pa yan if may 13psi pa na natira.
Just inspect visually after vulcanizing and pakiramdaman.
- Jun 2013
- 188
November 8th, 2019 03:25 AM #3
- Mar 2005
- 703
November 8th, 2019 04:58 AM #4The only way to know for sure is to remove the tire and check how much material got stripped from running flat. if it's just a speck, no worries. if its quite a bit, like more than 100 gms or rubber material...its probably compromised already and won't be safe to use anymore.
November 8th, 2019 08:22 AM #5
Tire size & specs? If not a low aspect ratio tire, chances of retaining whatever service life it had left should be above median. Have it thoroughly inspected upon fixing the puncture....then, move it rear, or better yet...spare. Diminished safety isn't worth the risk nor savings.
- 54,217
November 8th, 2019 09:15 AM #7yes, casa can repair punctured tires, just like every other tire shop.
but it'll take as long as an un-scheduled pms, and much more expensive.
hanap kayo ng ordinary tire shop along the way.
ps.
i always have a tire inflator in the car. i can inflate not-too-much-punctured tires comfortably, so's i can drive her to the tire shop for a more permanent repair.
and yes,
13 psi ain't so bad.
it's still drive-able. jut don't go running over big road imperfections, humps, and craters.
- Jun 2013
- 188
November 8th, 2019 09:44 AM #8
- Mar 2005
- 703
November 8th, 2019 10:03 AM #9Again, it's the inside that gets gutted and scratched up by the rim when a wheel is run flat. You have to remove the tire and see how much tire material got removed inside...where it got removed (most likely near the sidewall and tire thread area) and if there's a lot of material removed, it's a no-go sign. If you value your life.
- Jun 2013
- 188
November 8th, 2019 10:06 AM #10
Sanity check please... consider this hypothetical scenario. If I bought a new car in June 15,...
1st LTO renewal after 3 yr registration
