Results 1 to 8 of 8
March 11th, 2005 03:30 AM #1
I hear whistling/scratching noise when the car is moving.
Nawawala when I step on the brakes or the car is not moving.
Also I notice minsan naiipit yung brakes. When I'm hanging on an incline I don't roll even though the handbrake is not engaged. I have to step fully on the brakes to fix this.
Malakas naman ang brakes and puno lalagyan ng brake fluid.
Car is an ES civic.
Help naman mga peeps.
- May 2004
- 903
March 11th, 2005 05:09 PM #3Baka Breaks nga... Ganun din sa akin... Huhuhu.... I also check yung mags kung mainit para malaman kung which brake yung madumi or dumidikit.
March 12th, 2005 01:19 AM #4
I brought to a mechanic. They cleaned the brakemaster, changed and bleeded the brake fluid. I haven't heard the noise again (intermittent problem) but the brakes still seem stuck up.
March 12th, 2005 01:42 AM #5
Maybe you need to rebuild the calipers. Most mechanics can do that. Just buy a caliper rebuild kit (basically a box full of bushings).
March 12th, 2005 08:00 PM #6
The brake wear indicator, small metal thingie that sticks out when the pads reaches a certain thickness, in the brake pads is telling you it's time to change your pads. It sticks out hitting the disk rotor while driving, that's why you hear a scratching sound. The sound disappears when you step on the brakes because the whole of the pad is in contact with the disk. HTH.
March 12th, 2005 08:12 PM #7Originally Posted by afrasay
March 12th, 2005 08:28 PM #8
afaik, disk brakes.
saw our mechanic changed the pads on a camry. nawala yung scratching sound when breaking.
32nd Trans Sport Show 2024 One More Rev
