Results 41 to 45 of 45
- Jan 2008
- 4,726
November 24th, 2022 12:27 PM #41usually pag naka kita ka ng isang daga, may mga kasama yan.. kahit napatay mo yung isa.. expect mo na may bibisita ulit sa iyo na kamag anak nyan..
parang nasusundan nila kung saan nag pupunta mga kasama nila eh..
nung bago mag bagyong cho paeng, may nakita ako daga.. so i setup trap.. then expect my cars kasi baka may ngatngat.. buti wala pa..
next morning, huli ka balbon.. peanut butter sandwich ang ginamit ko bait..
pero setup ko ulit yung trap kasi alam ko may susunod.. lo and behold naka 2 pa ako sunod na nahuli.. 1 boy 2 girls
November 26th, 2022 08:22 AM #42
when you have your engine detailed, try using (no touch) tire dressing all over the engine. it gives a clean new look to the engine as well as the compartment. the slippery clean surfaces give a slippery surface and discourages the rodents from hanging around. you can also add napthalene balls is mesh bags where you suspect them to stay in the engine compartmet
- 52,731
November 26th, 2022 10:49 AM #44if and when i clean my engine bay,
it's usually half-hearted, using only using vasahan + water.
anything more, and it may simply attract dust.
my opinion.
November 26th, 2022 08:29 PM #45
high idle RPM at engine start
