Results 61 to 70 of 70
February 19th, 2008 04:44 PM #61
Shift down to D3 first. If you're still going too fast, shift down to D2. Just be careful not to let the engine rev too high under engine braking downhill.
February 19th, 2008 05:08 PM #62
M/T gamit ko. pag di gaano ma-traffic i'm on neutral from boni to guadalupe pababa kasi. i know na hindi dapat pero tantiyado ko naman saka di naman ako gaano mabilis and i stick to the left most lane. IMO masisira ang tranny pag mali ang release ng clutch, pero definitely adversely affected ang brake pads.
Tsikot Member Rank 4
- Jan 2003
- 2,979
February 19th, 2008 05:50 PM #64is this same for putting the gear to neutral before going to a full stop? I mean you let the car roll slowly while applying the brakes?
February 19th, 2008 07:44 PM #65
Uhm I have 2 questions:
1. Is engine braking still effective in high speeds? Is there a range of situations where it is effective? Or is it always effective regardless of the situation?
2. Is engine braking still effective in high-speed, emergency manouvres (emergency braking with or without steering)?
February 19th, 2008 11:09 PM #66
I use to cruise a lot before when I was still using a MT car. Nilalagay ko na sa neutral and let it cruise and step on the brakes to stop the car if I see traffic ahead and I will eventually have to make a full stop at that. I also use it a lot during downhills. I just didn't feel that it wore out the breaks faster.
But in AT I never do it I only place the lever in neutral if its a complete stop.
February 20th, 2008 12:05 AM #67
pag running low on fuel na ko, or talagang tipid time na, nag neutral ako kahit malayo pa sa stop light, basta me konting momentum pa.
February 20th, 2008 12:31 AM #68
i have done this everytime i'm entering a basement parking here in rcbc.
btw, mine is manual.
February 20th, 2008 02:04 PM #69
pag sa downhill at mabagal ang takbo ko, nag neutral ako.. pero pag mga highway or sa downhill at mabilis ang takbo ko hindi ko ginagawa ang mag neutral, may time na nangyari sa kin before mabilis ang takbo ko at nag neutral ako may biglang nag cut sa kin sabay nag preno na sasakyan di kumagat yung preno ko ayun nasapul ko..
March 3rd, 2008 08:46 PM #70
Im not sure but we towed our toyota corona before with out a dolly and we just placed the gearbox on neutral and we did not have any problem with the tranny
Xiaomi E-Car
