On The Downhill
Instead of using your brakes to slow your vehicle down on a steep grade, use what is known as "engine braking" (big-rig drivers use something similar called "
jake brake").
This is a good idea if you want to:
a) save your brakes a lot of unnecessary wear & tear
b) actually HAVE brakes at the end of the hill!
In fact, you will increase the life of your brakes by a few months (or even years, depending on how much steep downhill driving you do) if you simply use engine braking whenever possible, rather than actually pressing the brake pedal to slow your vehicle.
In short, you are literally using the engine to break the speed of your vehicle traveling downhill.
