Results 21 to 30 of 70
July 3rd, 2005 12:36 PM #21
Tama nga yung pag masyado steep yung downhill it isnt good to go neutral. Pag napapansin kong steep masyado I'd rather stay in 1st gear.
July 3rd, 2005 02:18 PM #22
Originally Posted by Karding
Tsikot Member Rank 4
- Oct 2004
- 2,315
July 3rd, 2005 02:34 PM #23pag konti nalang ang gas ko, what i do is go neutral. Not at steep inclines pero pag may mga stop lights. What i do is calculate my speed and distance. Pag inclines naman yun hindi naman steep at pag traffic or mabagal ka lang.
One time ginamit ko ang neutral mode kasi paubos na gas ko. Pag dating ko ng house binomba ko ng hose yun sasakyan kasi umuulan nun. Umusok ang disc brakes ko hehe sa sobra gamit at init
July 3rd, 2005 03:08 PM #24
i know d bad yung at to cruise in n, just don't step on the gas pedal, but for safety, don't do it.
- Jun 2005
- 113
July 3rd, 2005 06:17 PM #25Originally Posted by Alpha_One
Besides, I don't think the cops over there really bother checking drivers out for that. Not like if you were speeding, caught driving without seatbelts, busted tailight, didn't signal before changing lanes, cracked or broken windshield, etc.
- Jun 2005
- 113
July 3rd, 2005 06:19 PM #26Originally Posted by KCboy
- Jun 2005
- 113
July 3rd, 2005 06:27 PM #27Originally Posted by Karding
Heaven forbid I should get into a fender bender and the cop is going to figure out my tranny was in "Neutral" when my car made contact. I strongly believe that it can be proven how an a/t equiped car can actually stop quicker when shifted into "Neutral" during emergency braking.
July 3rd, 2005 11:52 PM #28
SAFETY - This is the primary reason why cruising in neutral is bad and even outlawed in some states (it is also outlawed in Subic). Sure no one will check if you are coasting or not, but then again, it is the safety of you and your passengers that you are compromising. I would not even care if you crash or not so long as you do not crash into me or anyone I know.
The reason for coasting being not good is because you will not have power when you need it (mbt has posted this already). Not all mishaps are avoided by braking. Some will require you to power-out of a given situation. And if the tranny is in neutral, you are losing precious time or you might even forget to re-engage.
Btw, during emergency braking of an A/T equipped car, the brakes will have no problem overpowering the transmission and engine provided you are not stepping on the throttle. Even at full throttle, the brakes will still overpower the drivetrain quite easily so there is really no point in disengaging the transmission. What if you suddenly needed power mid-braking? Slamming back into drive is very unhealthy for transmissions and you may not even have the presence of mind at the time to do so.
- Jun 2005
- 113
July 4th, 2005 07:48 AM #29Originally Posted by OTEP
On the matter of applying max braking, then max acceleration the next second, I don't think there's such a real-world situation, nor do I believe in the possibility of the success of such a maneuver. It's either you brake, brake and swerve, or accelerate; never brake and accelerate in such a short amount of time. If you come to think of it, braking and accelerating are both mutually exclusive and would only cancel each other's effects when combined together.
Besides, not even the quick reflexes of a seasoned F1 driver and the handling excellence of his purposely-built F1 car could demonstrate the plausibility of such a scenario in the real world.
Tsikot Member Rank 3
- Apr 2004
- 663
July 4th, 2005 09:23 AM #30Originally Posted by squala
hmmm... from what I gather here, long cruising on nuetral or doing it downhill is safety hazard.
For a MT you can cruise at nuetral when coming to a stop. I guess you can brake and make sure you are deccelarating first then shift to nuetral and continue deccelerating.
for AT, majority discourage it because the AT mechanisms work differently and safety is compromised.Last edited by RafRaf; July 4th, 2005 at 09:41 AM.
Interesting thread—really important to consider the broader impact of the National ID Law beyond...
National ID Law
