Results 11 to 17 of 17
December 16th, 2007 10:39 PM #11
In a way nakarelate ako dito. Yung sakin po kasi pag umaga, habang pinapainit yung sasakyan, tubig na may halong parang abo` yung binubuga or dinudura(sorry for the term) nung tambucho, pro nde naman po siya langin kasi po hinawakan ko yung binugang tubig na maitim. Or langis po talaga yun, kaso muka lang pinaghalong abo` at tubig? Tapos po yung usok na nanggagaling sa tambucho is white naman po not blue. kaya po mejo naconfuse ako. hehehe...
*ASUS700
Nacheck ko po yung battery, ok naman po. Iam setting aside po yung battery since Bagong palit lang po ako nung end of nov.
Tapos po pag "Igniter" naman po yung problema, tama po ba na kahit papano mag-reredondo yung sasakyan, tapos hanggang redondo lang pro hindi magiistart?
Tapos po pagka naman po "starter" po yung problema, kahit anong pihit ng susi sa start, walang nangyayari, ni-redondo, wala po? tama po ba?
December 17th, 2007 03:47 AM #12
Dont assume your battery is working properly even just bought that recently/ A dead battery not really a bad one it just lost the charging system. Try check your battery if it is good, turn on your doom lights and start your car, if your doom light didnt go dim then probably its good. If your doom light goes out or it dim, your battery charging system is low. Recharge it before use.
If all this are fail to solve your problem, check your battery connection for corrosion in the terminal and the cable connector, clean it and tighten all the bolts. If this still wont work then remove your starter to have your solenoid check this causing starter will not cranked or not a click sounds because your solenoid is bad.. This the most common problem of a car involving no current. Remember that this is electrical not mechanical so your problem is mostly dealing with ignition (DC)system. Kapag hindi parin masagot yong problema eh......palit nalang ng kotse. Joke lang .
December 17th, 2007 09:49 AM #13
tama po.
had the same problem before. i turn on the key to start, just a click happens, no redondo at all. battery was drained, had it recharged and okay na. the following day ganun na naman.
turns out that the alternator was bad, it was draining the battery overnight. nung pinalitan ko yung alternator, okay na.
look into v6dreamer's post also.
December 18th, 2007 12:21 AM #14
Just an update.
I had my car checked kanina, and fix my car problem, it turns out that the starter is the problem. The electrician had removed the starter and fix it. I only spend around P150 pesos for the replacement of parts inside the starter and P300 + P50 bonus for the labor and "whaalla" one click and the engine starts running. haaay... at least mejo magaan sa bulsa.
*ASUS700
natawa naman ako sa comment mo "Kapag hindi parin masagot yong problema eh......palit nalang ng kotse."
Anyways thanks for the advises guys.
- Dec 2007
- 7
December 19th, 2007 05:52 PM #16ok tong thread na to. kakakuha ko lang ng 1991 corolla ganun rin yung experience ko pag cold start. kailangan pa mag gas ng tatlong beses para
di mamatay yung makina.
yung akin naman may usok daw pansin ng kapatid ko nung nakasunod sa sa skyway. magkano ang aabuting gastos. kaya kaya sa tune-up yan.
December 20th, 2007 01:18 AM #17
i don't like hybrids so corolla cross is out for me. but i'd consider a non-hybrid corolla cross...
MG4 EV Standard vs BYD Atto 3 Dynamic vs Toyota...
