Results 21 to 25 of 25
June 27th, 2007 06:43 PM #21
1. I bought it off the web a few years back. I still have an extra unit actually...pero the brand is Permacool
circuit board construction Kit includes all of the components for single fan installations. 160-210 degrees F adjustable thermal switch module with unique silicon chip temperature sensor that ensures accurate temperature readings to within +/_ 1 degree F. Pre-wired module wiring harness, fuse block power taps, in-line fuse holder with 25 amp fuse, wiring diagrams for single and dual fan applications and illustrated instructions are included.
2. Both are sold separately
3. No problems at all
4. Yup, certainly improved performance. Engine feels lighter due to the less load that was being sucked up by the belt fan dati. Mas perky sya
5. Kiddo Jr. is my present Vitara. Kiddo Sr. is my former Vitara that was involved in a carcrash
June 27th, 2007 06:55 PM #22
sir wiretap, may nabibili kaya nyan dito, kahit di kit, piece by piece?saan tap nung sensor? mukhang magandang DIY project yan,a...
June 28th, 2007 02:24 PM #23
hanep, hanep!
magkano po ba bili mo yan sa web?
did Sr. crashed kasi tempting ang power niya?
June 28th, 2007 07:34 PM #24
$54.99 sa jegs.com
Its an extra set so I'm selling it in case you're interested. Convert mo nalang price to pesos
Nope Kiddo Sr. Didn't crash. http://www.jegs.com/webapp/wcs/store...44387_-1_11471
Yung sensor is a a core-thru type. Bale you insert it thru the fins of your radiator that are closest to the inlet pipe. May cap sa harap para accurate yung reading.
July 1st, 2007 10:48 AM #25
that's a good price... wish i could buy that from you right away sir. but I don't have a budget for that right now.
kung wala pang bumili nyan sa inyo in many months, I'll bother to ask you sir.
salamat po.
high idle RPM at engine start
