Results 21 to 30 of 36
August 26th, 2006 01:37 AM #21
Cool it guys! When I doubt, just read the Owner's Manual of your vehicle, ok?
August 26th, 2006 06:18 AM #22
You didn't get what I intent to have said, in my early posts, I said you didn't have to wait 5-10 minutes, while on my previous post, I said it will take you 3 minutes you get to measure the reading after you shut off the car. Did you think I was telling you to pull over, step off the car, open the hood then go back to your car to shut it off before you pull out the dipstick?
wahhhh... you'll know when it's overfilled when the dipstick says it's overfilled when the car is warmed up! Damn! You're not supposed to measure the oil level when the car is COLD so why say it's FULL when it's COLD??? Damn . . . :waah: How many times do people gotta ask questions that have already been answered?!
the temp of the oil when car's running isn't the same as the temp of the oil after you turn it off for 3 minutes! Again, you should not refer on the level of reading when the car is COLD!
Dang, I'm done with this thread... I don't need to say things over and over, I've said it all, measure your oil when the car's cold if that's how you want to do it... mbeige, you don't make sense at all...
August 26th, 2006 07:44 AM #23
Tama!
And this is what mine says:
With the engine at normal operating temperature and engine is off...
1. Best to be on level ground... wait a few minutes for the oil to drain back... Pull dipstick out.
the_wildthing: Sorry, forgot the exact words on my way up. Pero sigurado akong walang nakalagay na exact minutes pero may rason kung bakit.
2. Wipe with a rag...
3. Put dipstick back all the way in.
4. Pull it out and check the level...
the_wildthing: may drawing pa.
August 29th, 2006 04:04 AM #25
Yup, I also measure several minutes after the engine has warmed up and shut down. It's in my manual, and that's what I was taught in several seminars I have been made to attend as part of our company fleet accreditation/education.
Probably, some of the other cars' dip stick were calibrated on a cold engine?
August 29th, 2006 07:01 PM #26
Another Page 10 thread in the making? Hehehe, c'mon guys, lets not get all worked up over a petty thing like this.
Basta ako, in my manual (Honda), approx. 4 liters ang capacity ng engine, so, cold engine or not, I always ask my mechanic to put in 4 liters (together with a new filter)
- Jan 1970
- 396
August 29th, 2006 07:08 PM #27i just did a little experiment. i measured the oil with a cold engine, car was parked over night.. and earlier today, i measured it with about 3-5 minute drain time, so warm engine pa din.. and guess what.. halos di ko man lang makita difference in oil level sa dip stick!!!
- May 2006
- 913
August 29th, 2006 08:11 PM #28wow, i didnt thing this tread was goin to be so exciting. hehehhe... for me i think its best to wait 5mins to before u check your engine oil.by the way i think that NAscar race cars have dry sum oil systems, so i think it would be different, from normal private cars.and i have also noticed that some cars have on the dipstick an add mark and a full mark. and like they say if ur oil level is between the 2 then your in the clear.anyways thanks for the insights. and ya i agree wit slip-slick, theres hardly a difference. whether the engine is cold or hot. because we liv in the tropics, where the weather is fairly the same temperature. in colder countries there might a significant difference.
August 29th, 2006 08:20 PM #29
- Jul 2006
- 34
August 29th, 2006 09:53 PM #30
high idle RPM at engine start
