Page 2 of 2 FirstFirst 12
Results 21 to 33 of 33
    Oct 2008
    #21
    Quote Originally Posted by Lew_Alcindor View Post
    BTW, I do not use the cig lighter outlet or the aux power outlet.
    What I did was to remove the adaptor plug and replace it with clamps (the red and black one). Then I connect it to the battery (+) and the somewhere in the vehicles body (-).
    any problems using the lighter plug sir?
    Oct 2008
    #22
    Quote Originally Posted by skybison View Post
    COIDO (Japan). Available usually on mall hardware (ACE, Handyman, TrueValue)
    thank you sir...
    Apr 2012
    #23
    Meron po ba kayong alam na pwede sa 220V at pwede din sa 12V cigarette lighter na tire inflator? Kakagamit ko lang ng Coido brand, kaya naman niya iinflate ang flat tire na fully deflated.
    Apr 2014
    #24
    Quote Originally Posted by eminem6480 View Post
    Imposible yan. DC ang 12v sa kotse.
    AC naman ang 220v sa bahay.
    Jul 2011
    #25
    Ung iba meron kasama adaptor, 220v convert sa 12volts. Every time na magpagas ka pa lagay ka na din hangin para regular no makita status ng tyres mo, pag madalas meron diff ng 5 psi pa check mo na gulong mo. Tyre inflator ko 5 years ng nakatago nagamit ko lan sa pag inflate ng basketball.
    Aug 2012
    #26
    Ito mga gamit ko:
    Automatic, Digital Tire Inflator. You can set the pressure you want and it will stop automatically when target pressure is reached. You can store into memory so no need to set next time. With backlit LCD display and LED light (Red and White).
    220V to 12V Adaptor with Cigarette Port.
    Both can be ordered from D3 Technologies.
    https://www.facebook.com/d3techph/
    Oct 2013
    #27
    gamit ka power supply ng computer, dun mo kabit 12v
    #28
    bought this one sa OLX for P2,400 brand new.
    Jul 2013
    #29
    Quote Originally Posted by 5000rpm View Post
    I fried some electronics accdg to CASA. The advisor called it an ecu for the electrical system. Had replaced it under warranty.
    I suspect it is more of a vehicle defect but I decided not to plug my tire inflator there. Anyway, I find it more convenient to connect it directly to my batteries.
    Apr 2012
    #30
    Quote Originally Posted by chronicle View Post
    Sir, may nakita ako online. Nagbabakasakali lang na merong available dito sa atin locally.
    Amazon.com: Kensun AC/DC Heavy Duty Air Compressor Tire Inflator: Automotive
    Amazon.com: Black & Decker ASI300 Air Station 12-Volt or 120-Volt Inflator: Home Improvement
    Jul 2013
    #31
    Bakit naman gusto mo na mai-plug pa sa 220V (or 240V)? May indoor need ka ba para sa tire inflator?
    Apr 2012
    #32
    Yes sir, para sa iba pang items like indoor pool, airbed, etc. Probably, bibihira ko lang magagamit ito kung for car use. Para masulit na din .
    #33
    you can buy a car cigarette lighter adaptor.
    you plug it into a home 220 V socket, and it has the usual car cigarette lighter receptacle that you can plug your automotive appliance into.
cig plug tire inflator
