Page 1 of 2 12 LastLast
Results 1 to 20 of 33
    Oct 2008
    Planning to buy one... but as I read through some of the posts here, I have read that most of the electric tire inflator doesn't last long... anyone who happened to have tried this?
    Amazon.com: Viair 00073 70P Heavy Duty Portable Compressor: Automotive
    Or are there any being sold here locally that would last long?
    Thanks..
    plastic pistons don't last long. pag uminit na sira na.
    it only costs me P20 in tip to the gasoline boy every 2 months to inflate my tires. that is only P120/year. if your need to have a tire inflator is for emergencies then you are better off buying a can of compressed air or emergency tire inflator.
    this
    (i have 2)
    or this
    naghahanap ako ng ganito kasi mura lang CO2 canister e. san kaya meron.
    Oct 2008
    Thanks for the input, but I am opting for a durable electric inflator as I am also planning to buy tire pressure monitoring system (external), with these installed, it would be a hassle for me to get off the car everytime i go to a gas station just to remove the caps for the gasoline boy.. i would love to have an inflator so I can add more air if needed whenever/wherever....
    Meron ako tig isa for emergency. But para di mahirapan better to jack it up before using in case sa SUV (never pa naman nagamit knock, knock) Mas nagagamit pa sa bike and bola ng anak ko .
    Sa cars kaya itayo kahit no jack. With regular check sa gas station with reliable gauge.
    Apr 2006
    kung pang-top off lang naman, tatagal naman yung mga cigarette plug tire inflator. i use coido which is cheap. parang 2006 pa yata siya. wag mo lang siguro gagamitin to inflate a fully flat tire. after mga 10mins of cotninued use which is more than enough para ma-top off mo 4 wheels + spare tire, ipahinga mo sandali bago gamitin ulit.
    yung mga maliliit mabilis masira yan.... i used to have one that conked out after one year. once or twice ko lang ata nagamit yun sa gulong, the rest sa mga bola and porta pools.
    ngayon, i am using a heavy duty one.... naka embed yung unit sa sarili nyang hard case.... got it from the US 4 years ago.... and now it is still working, although the gauge is inaccurate... pang emergency purpose lang naman like the other week. when i went out of the garage, i saw that the tire is flat... onting bomba lang just to run the car to the nearest vulcanizing shop near my place (around 1 km.), instead of me changing the tire...
    the usual, i check my TP sa gas station every two weeks.
    Jul 2013
    Consider this one. Locally available (ACE, Handyman, etc)
    I bought mine like five years ago and it is still working fine. It says it can run continuously for 30 minutes but I have not used it for that amount of time. But it served me well. I can inflate a tire from completely flat to 30psi in around 5 minutes (vehicle not jacked up).
    I probably use it maybe twice a month.
    I have smallest model BTW for arounf Php1,300
    Oct 2009
    mayroon akong gamit kaso 220v galing un sa hospital binigay sa akin ng uncle ko kasi lumang na daw un.ginagamit nila un sa parang nobolizer nung araw pa daw un.
    220v siya na sing arround 5 inches ang bilog niya at 8 inches ang haba,pero full metal siya.kaya sobrang tibay talaga.
    nilagyan ko nalang ng hose.tapos bili ako ng inverter..hanggang ngayon gamit kopa din sa bahay..kaya niya hanggang 100 psi
    Quote Originally Posted by 5000rpm View Post
    Thanks..
    i have this. and i have used it several times.
    it's the first tire inflator that i can confidently recommend to my friends.
    i don't remember the brand pasted on the product, but the shape and trimmings, and fabric sheath, are exactly the same.
    Jun 2011
    For emergency use only. This inflator does not have a (wet) tank and will introduce or inject moisture and condense as water inside the tire causing corrosion and potentially damage the TPMS sensor
    Mar 2005
    Yung Elevo na Cig pump, 6 years na sakin buhay pa din. Ilang beses na ko nasalba tuwing nag kaka flat tire ako. Pagka inflate na ba byahe ko pa papuntang vulcanizing shop.
    Oct 2008
    Thank you for all the inputs, really appreciate it.. i thought of buying TPMS kasi there are times na when I go to gas stations ang haba ng pila, especially pag may nakapila pang trike.. and then there are times naman na hindi functional yung compressor nila.. atleast with the TPMS I can monitor my tire pressure, and then just top it off with a portable tire inflator if needed, for emergency purposes na din..
    *dr d. thanks, atleast now I have a testimonial from a first hand user
    Meron naman iba na will last long kagaya ng gamit ko na more than 10 years na at gumagana pa. Always nasa likod ng sasakyan in case of emergency. The one I have is made in USA kaya siguro matibay.
    May 2011
    currently using this
    around 4yrs+ old already, seldom used. I think should limit less 10min of continuous use - have to rest for a few minutes dapat. Afaik, 250psi can't inflate a fully deflated tires that's why i got 300psi.
    ginagamit ko lang minsan kapag tinamad palit ng reserba - pang tawid lang sa gas station para pahangin or nearest vulcanizing shop.
    May 2012
    Quote Originally Posted by jmpet626 View Post
    it is a good brand. heavy duty saka di plastic. may ganyan ang brother ko naka stock sa bahay nila. hinihingi ko pero ayaw ibigay.
    Oct 2008
    *skybison
    anong brand yan sir? can't quite read the text... thanks
    Oct 2008
    Quote Originally Posted by Lew_Alcindor View Post
    will take a look on this one too..
    Jul 2013
    BTW, I do not use the cig lighter outlet or the aux power outlet.
    What I did was to remove the adaptor plug and replace it with clamps (the red and black one). Then I connect it to the battery (+) and the somewhere in the vehicles body (-).
    May 2011
    *skybison
    COIDO (Japan). Available usually on mall hardware (ACE, Handyman, TrueValue)
    errr... whypo?
cig plug tire inflator
