Results 11 to 20 of 24
    Yung sakin laging 3.75 lts ang nilalagay pero pag tingin sa dip stick ay laging lampas dun sa level pero wala namang nangyayari.
    Jul 2006
    Lampas siya during cold dahil you check the engine when warm. When it's warm and you check the engine, the oil is still in the engine upper components. But this is good dahil this is what you want, maximize the amount during operation.
    Mar 2005
    Could damage gaskets. Damaged head gasket could get oil into coolant and vice versa.
    If oil level reaches crankshaft it will be whipped into a foam which won't lubricate well. Exacerbated by driving fast through corners, centrifugal forces will shift the oil.
    But apparently there's a bit of safety margin for oil overfill...
    Kung hindi naman grossly overfilled, don't lose sleep over it. Hindi ka naman pagsasakluban ng langit at lupa.
    How much did you overfill ba?
    Aug 2005
    kasi pagtingin ko po sa dipstick lampas ng 2mm.
    Mar 2005
    Quote Originally Posted by dj_ryankilmore View Post
    2mm is nothing, but you might still want to drain off the excess, or suck it out of the dipstick tube.
    i think 0.25 liter ata kasi 3.75 sa manual eh 1 gallon=approx 4 liters yun.
    Feb 2006
    ah ganun pala yun
    Jul 2006
    Quote Originally Posted by afrasay View Post
    Beg to disagree--DO NOT remove any oil kapag ganyan. Tamang tama lang sukat mo.
    See below:
    Quote Originally Posted by mbeige View Post
    ok lang yon dahil 3.75 liter = 0.990 645 192 gallon [US, liquid]
    http://www.onlineconversion.com/volume.htm
    See below:
    Agree din ako. I was just answering Otep's question on how much ang sobra.
On changing oil/what will happen pag sumobra?
