Results 1 to 20 of 24
    Aug 2005
    tanong lang po...
    Jul 2006
    It's like drinking too much water. You will soon be forced to get it out. Same with the engine pag sobra talaga like maybe 2 liters above max. The oil seals/gaskets/O-rings will have too much burden because of the increased pressure (affected by increased volume).
    Drain just a bit into a good clean container and then fill up to proper level.
    Aug 2005
    so the engine will be running at less than the optimum level(parang lunod)?
    Jul 2006
    Yes, dahil hirap siya. Pero if your car is a diesel, and it burns oil, ok lang yan
    In essence it's bad for the rubber seals that hold the oil in to generate the proper pressure to circulate, lubricate and cool your engine. Thicker weight oil can do more damage if overfilled than thinner oils.
    Aug 2005
    yikes... tnx sa info *mbeige
    tama si mbeige. also when oil gets hot it expands. thus the increase of pressure inside. too much oil means higher oil pressure than usual. that's when leak starts, assuming sobra nga ang oil mo...
On changing oil/what will happen pag sumobra?
