Page 1 of 3 123 LastLast
Results 1 to 20 of 49
    May 2005
    hi! newbie po ako sa tsikot. simple question lang po. pag semi synth ang oil na ginamit sa oto, gano po katagal (ilang KM o months) bago magpachange oil ulit??
    TIA!
    Oct 2003
    well, people here would suggest you stick by your manufacturer's guide, every 5K or 10K preventive maintenance schedule (PMS). i suggest you do that.
    Quote Originally Posted by zechs
    Ditto.
    We use semi-synth on our Sentra but still change every 5,000km.
    Mar 2005
    Basta change ka lang every 5k km.
    May 2005
    every 5k kilometers or 3 months, which comes first.
    Aug 2004
    good to change oil every 5kms
    Dec 2003
    Quote Originally Posted by mcbry
    typo error siguro... magastos kung ganito hehehe
    well, they all said it.. every 5k kms ang change oil..
    Mar 2005
    Has anyone used acdelco semi synthetic oils? just want to know how is it compared to other brands particularly yung shell and caltex oils in terms of performance and fuel efficiency....so far havoline energy is the best sa fuel consumption...
    Aug 2004
    Quote Originally Posted by mugen
    sowie sowie... 5k kms nga ibig kong sabihin
    Nov 2003
    your oil should be replaced depending on milage and driving conditions.
    May 2005
    so mas ok ba yung havoline compared to shell's oil??
    thanks ebriwan!! :D
    Feb 2005
    What's the best semi-synthetic oil recommended that not so expensive?
    Feb 2005
    how much po ba mag pa change oil?
    Jul 2003
    sir madmaxmaloles, sabi nila huwag ka na daw mag semi-synth, choose between synth and mineral nalang...
    Feb 2005
    Quote Originally Posted by pissword
    Thanks for the advise. anong best for both type of engine oils?
    Nov 2003
    semi syn is allright pero you might as well just add a couple of hundred for the full syn. if not, go for regular and just replace it more often.
    about the oils, i personally stick with the bigger brands like mobil and castrol since i've had a lot of experience with these. more important than brands tho are the letters and numbers on the oil container. learn to decode the ratings, viscosity, etc of the oil so you know which one is the best for your car.
  17. #17
    speedyfix: How long is the interval for the mobil1 0w40?
    May 2005
    sir speedyfix...in your opinion, ok po ba yung shell helix plus for a '95 civic esi? semi-synth po ba ito? what would you recommend for the said car? TIA!
    sir aces_fan... nung nagpa-change oil ako last month, if i remember correctly, mga 1.5K sa SHELL (helix plus) including oil filter....
    Nov 2003
    well, it depends how you drive. i still replace it every 3-5000kms depending if i'm really abusing the engine. hehe! for more normal driving then you can go between 5-10k kms with it.
    izzy, well since the oil is in the car then i say keep it na. palit ka nalang to full syn next time if it's within the budget.
    May 2005
    Quote Originally Posted by speedyfix
    thanks!
change oil...
