what about Pertua? has anybody here ever used this oil? feedback naman...
repackaged here in the philippines... no idea tho about how good it is.
It's best to stay with the manufacturer's recommended oil grade.Originally Posted by buknoy2002
On the other hand, it might even be beneficial to use thicker oil on older engines to compensate for the increased parts clearances, and minimize engine noise and enhance compression at the same time.
Oil change 5,000 KMS or 6 months which ever comes first regardless of the oil that you are using.Originally Posted by izzy
Matagal na yan ha. Alam ko hindi nag-click yan eh. Meron pa ba nyan sa market?Originally Posted by box_type
On older cars, it is better to use thicker oils. Thickest grade available here are shell and castrol RS for synthetics. in the US, there are thicker grade synthetic oils recommended for high mileage engines.Originally Posted by buknoy2002
yes, high mileage cars have bigger clearances on the ring-cylinder wall, and valve stem-valve guide areas which could cause leaks to the combustion chambers that resulting carbon build-up in that area.
use the thicker grade if you want synthetics or better yet, use the dino (mineral) oil and just replace frequently.
