Results 1 to 10 of 17
June 25th, 2006 07:43 PM #1
there is a stretch of road i drive daily sa amin na maraming lubak caused by water pipes. these are diggings crossing the road for water pipes pero hindi na tinabunan ng maynilad.
according to a driver neighbor, dapat daw iba ang treatment ko when driving over them. pag yung bump daw kasi pataas (like yung ordinary speed bumps na pataas), i should slow down. pero pag itong mga ito, i should maintain speed as not to feel the full force of the "tagtag".
usually, i slow down. pero dati di ko napansin na i was crossing one and parang totoo yung sinabi nya na it's better when you're going over them fast.
any thoughts from you guys?
June 25th, 2006 08:05 PM #2
At times nga, pag tagtagan ang usapan, mas hindi ko nga rin ramdam pag maintained ung running speed ko. More better to ask would be this though:
Ano effect nito sa shocks ng sasakyan? which is worse for the car, ung maintained speed or slowing down?
Toyota is my choice
- Aug 2005
- 2,063
June 25th, 2006 09:28 PM #3Slowing DOwn para sakin.. di nman as in "tag" basta slow lng like a diesel engine climbing uphill with lubak2x condition..
June 26th, 2006 02:53 PM #4
palagay ko depende sa lalim at diameter ng lubak eh. pero kung yung tsikot mo pang-off road, malamang matibay tibay yan.
June 26th, 2006 03:17 PM #5
yup depende sa lapad pag smaller than the contact patch, drive over it, the momentary lift dahil sa speed mo will make the ditch unnoticeable, pero kung wider than contact patch, sakit sa gulong yan.
June 26th, 2006 04:32 PM #6Originally Posted by batang_raon14
ngayon sa tanong mo na which is worse for the car, ung maintained speed or slowing down? i would better slow down lalo na kung lubak talga or humps.
q:-)
June 26th, 2006 04:48 PM #7
well, if you slow down to a point na gapang talaga walang effect at all sa suspension mo... that's the best option.
June 26th, 2006 07:53 PM #8
*buoey_tisoy
baligtad naman yung narinig ko. pag mas mabilis ka daw, mas mabilis kang mababasa as compared kung mabagal ka maglakad/tumakbo
back to the topic:
mukhang ok yung medyo mabilis sa case ko. wag lang harurot at malawak(?) yung hukay. ok lang malalim basta yung diameter ng lubak ay significantly smaller kesa sa diameter ng gulong ko
June 26th, 2006 08:14 PM #9
depende yan. ako pag maliit ang gulong nang dinadrive ko(read: sedan), slow down talaga kasi eventually it will take toll on your underchassis parts. pero kapag yung malaking gulong (read: pick-up) ang dala ko, ok lang, kasi sturdy naman ang pang-ilalim. pero ingat pa din. tagtag e.
Toyota is my choice
- Aug 2005
- 2,063
June 26th, 2006 09:31 PM #10unless kung tag tag na talaga shocks mo and go for it! 10kph ka or more! hehehe..
slow down lang.. ang rack end mahal, bushing , suspensions etc. :lol:Last edited by finchy18; June 26th, 2006 at 09:33 PM.
high idle RPM at engine start
