Results 31 to 40 of 42
- Aug 2014
- 60
February 16th, 2017 10:19 AM #31i've never used one - yung alanganin sa parking o sa lusutan, sisilipin ko labas ulo while backing or even stop, get off and visual check.
but i do use clip-on convex rear view mirrors to see the rear quarters - eto mas ok with proper side mirror adjustment.
February 16th, 2017 10:23 AM #32
On large vehicles (SVU and van) I use the small round ones stuck on the side mirror, for the RH side only. Allows me to see if there's anything hiding or lurking low on the right side in tight spots.
- Aug 2015
- 862
February 16th, 2017 10:30 AM #33dont stress over this, basta bumili ka na barya lang naman yan and removable/reversible naman in minutes. no need to research on the brand, basta may angle, maliit lang and adjustable. for as low as 50-100 malaking tulong na sya, lalo na kung mejo luma na auto mo ung side mirror square-ish lang hindi yung may kanto pababa.
- May 2017
- 10
May 20th, 2017 10:28 PM #34
June 27th, 2017 04:30 PM #35
Hi! Can anyone share their opinions on the best place to put the blind spot mirror and why? Thank you all!
June 27th, 2017 04:51 PM #36
explorer side mirror...
- Sep 2017
- 7
September 5th, 2017 12:59 PM #37
September 6th, 2017 04:00 PM #38
September 6th, 2017 06:27 PM #39
^ may nakita ako halos ganyan sa true value atc
when you look into the abyss, the abyss looks into you
- Jun 2015
- 204
And also edit option is not allowed anymore :grin:
Problems with viewing Tsikot on non-Chromium...
