Results 21 to 40 of 42
    Oct 2015
    Yung nabili ko walang brand name eh. Sa Ace ko nabili. Maliit lang na medyo angled yung mirror tapos narorotate. Almost a year na rin at dumaan na ang tag-init at tag-ulan (walang bubong ang parking) buo pa rin at malinaw.
    Mirage ang oto kaya malamang almost same size lang tayo ng side mirror.
    sent via Tapatalk
    Ganito yung nakita ko kanina sa ace..
    Sabi sa akin e hindi daw naiikot.
    Jun 2015
    Same sa lower pic yung akin. Actually nung bumili ako ang sabi hindi daw naiikot pero nung nabuksan ko na naiikot pala. Kung less than 100 lang naman try mo na.
    sent via Tapatalk
    Jan 2009
    I have the adjustable one. Helps a lot when changing lanes.
    Sep 2013
    I tried it once but I remove after using for 5 days only. nakakailang, di lang siguro sanay. may tamang adjustment sa side and rear view mirror sa youtube. proper setting your mirrors correctly, you don't need a blind spot mirror already. IMO
    Oct 2015
    sent via Tapatalk
    Ok. Thanks sir. Ma try nga. Midyo mahirap kasi mag parking sa amin and maliit ang mirror ng eon ko.
    Feb 2012
    Ako din sir meron dati sa aveo ko, just used it for few days and remove it. Nakakailang para sa akin
    Jan 2009
    These things, when strategically positioned, will also allow you to have an almost 360-degree view of whoever or whatever is approaching your vehicle while stationary (ie. traffic stop, parked). This will give you time to take defensive measures, fight, or flight.
    Dec 2015
    Feb 2017
    Quote Originally Posted by urbanmetal View Post
    Same here, sir. Then nag install na lang din ako nung clip-type na malaking curved rear-view mirror, really effective IMO
    pano pag rectangle yun shape, sa lower outer part parin ba ng side mirror lagay?
    Aug 2014
    i've never used one - yung alanganin sa parking o sa lusutan, sisilipin ko labas ulo while backing or even stop, get off and visual check.
    but i do use clip-on convex rear view mirrors to see the rear quarters - eto mas ok with proper side mirror adjustment.
    On large vehicles (SVU and van) I use the small round ones stuck on the side mirror, for the RH side only. Allows me to see if there's anything hiding or lurking low on the right side in tight spots.
    Sep 2012
    Just get the one na medyo slant and adjustable
    Sent from my Asus ZenFone 2 using Tapatalk
    May 2017
    Quote Originally Posted by dishcom View Post
    Sino po gumagamit ng blid spot mirror sa inyo? Ok po ba??
    Big help po sya especially for smaller cars 😁
    Apr 2014
    Hi! Can anyone share their opinions on the best place to put the blind spot mirror and why? Thank you all!
    explorer side mirror...
    Wala ba ganito shape sa retail stores?
    Sent from my SM-C900F using Tapatalk
    Sep 2017
    It's very helpful. Prevented a lot of accidents for me especially sa BGC/C5 where motorbikes tend to swarm around and just dart across cars
    ^ may nakita ako halos ganyan sa true value atc
    when you look into the abyss, the abyss looks into you
    salamat, makapasyal pag uwi ko pque this week :D
Blind spot mirror.. sino gumagamit?? Big help ba talaga??
