san shop gumagamit ng bearing puller? yung sa front wheel ko kasi maingay na. yung iba kasing pinagtanongan ko pukpok lang ang ginagawa eh. salamat!
you can have the hub sent to the machine shop for pressing. that's what we do.
hindi ko pala kelangan magpalit pa ng bearings. hehehe...
para kasing sirang bearing yung tunog kapag tumatakbo.
eh nung nagpalit ako ng gulong, nawala!
pinakinggan ko sa lahat ng speeds, 10 -20 -30 - 40 - 60 - 80, wala na
yung "wug-wug-wug" na tunog.
buti na lang.
kakapalit ko lang ng front wheel bearings (inner and outer)...
after 2 weeks, may naririnig na akong tunog sa wheel (driver's side) pag umaandar un car
sounds like "wug, wug,wug" getting faster un sound as the car rolls faster.
then i found out lumuwag pala un locknut nun sa bearing. kaya pala maalog din un gulong when i jacked it up.
binalik ko sa pinagpagawan, then hinigpitan ng "onti" un locknut, then after test drive, lumuwag uli!!! tapos sinikipan na using x-wrench
what seems to be the problem here??? gano kahigpit ba dapat un locknut?
Part 2: (kanina lang)
may naririnig na2man akong similar sound just like before nun maluwag un locknut, so that's my suspicion. dinala ko uli un car sa pinagpagawan for the 2ND time then pagjack nila di na maluwag, pero the sound still exists!!! they cannot determine the issue.
i doubt this time, baka nasira na un bearing coz of those times na maluwang xa tapos pinapaandar ko OR sobrang higpit naman un locknut this time.
please help me on this. bothering talaga un problem. thanks
Hi Colt, yes puede mo din basis yung vibration sound na "wung-wung" when the tire is rolling. Pero sometimes kasi, that kind of sound is also caused by tires. My suggestion is pa pull out mo bearing, then put your finger in the bearing whole then paikutin mo bearing, pag may naramdaman kang paramg may sumasayad or gumagalasgas pag umiikot palitan mo na siya (may tama na bearing), or pag wala naman ipabalik mo bearing then pa re-pack mo yung grasa ng bearing. Another way of checking your bearing is, pa lift mo sasakyan pero dapat yung naka hang yung tires, then hawakan mo top and bottom ng gulong then galawin mo, pag may play yung tires may possibility na din na may tama bearings mo. I hope this could help, it's based on my experience din.![]()
Hi Junddog, pag lumuwag lock knot, baka may nasira na sa ipin niya kaya di na kumagat. Ang lock knot kasi pag hinigpitan di na dapat gumalaw. Or kung nag palit ka ng lock, baka hindi exact na knot nabili mo.
Sa part 2 mo possible nasira na nga bearing, pa buksan mo uli then check the bearing. Tapos kung sira bili ka na ng brand new para sigurado (United Bearing na stores) na Genuine. Kung may tunog pa din kahit brand new na bearing, check mo na din yung tires mo, baka di pantay pag ka pudpud kaya may vibration sound.![]()
Last edited by jcastillo932; February 5th, 2007 at 02:29 PM. Reason: hin to hindi - Sorry
may way para ma tighten ang bearing, the old fashion way is to tighten it until you cannot turn the hub, then loosen it until it turns freely. this is the same as seating your bearing. of course nowadays a torque wrench is use to tighten it. your lock nut getting loose could be due to the following, the lock cap is not bend enough and the lock pin was not spread enough to rest on one of the groove of the nut. also the two screw of the lock nut in the case of a axle with a locking hub (4x4) could come loose if nut impact tighten properly.
btw, usually yun rear axle bearing ang need press out and press in sa machine shop. in rear wheel drive cars, you take out the axle and take it to a machine shop to do this.
thanks sa mga replies nyo. mejo na-tuto narin me.
now parang nawala na un tunog. naging intermittent na xa.
dko lam kung kelan uli susumpungin.
muka yata crucial un part ng pagpapalit ng bearing???
kasi pag namali sa pagbalik, pagsikip at pag-sit ng bearing, bale wala lang pagpalit ng bago. perwisyo pa ang aabutin pag di maayos pagkakagawa.
too bad, nararanasan ko rin to currently. hay.
un nakakainis eh, bumayad ka na ng labor tapos palpak pa ang gawa.
tuwing naririnig ko un ingay sa gulong/bearing parang sinisisi ako ng auto at bakit di xa naayos ng tama! Grrr![]()
san shop ba magaling pag dating sa gantong problema???
at magkano usually labor sa inspection at pag-gawa?
[SIZE="2"](hay, gastos nanaman...)[/SIZE]
i had my front wheel hub bearing (left only) replaced. old bearing was pressed out and the new one was pressed in. so i was confident na ok ang trabaho (walang pukpok). But the same noise is still there. ibabalik ko sa pinagpawaan ko la lang time pa... balanced naman tires ko and aligned naman kasi i tried to cruise the car at nlex 120-140kph di naman nag wiwiggle. and wala rin namang kabig? but from your experiences what could be causing the annoying sound? thanks!
di kaya sa roads na dinadaanan mo. yun concrete usually mas maingay kaysa sa asphalt.
